6k launch riping through exedy stage 2?
My two step is set at 6k, I have 1200 miles on my new exedy stage 2, and the clucth was slipping hard on launch. Is 600 stop and go miles not enough or did I get a weaker pressure plate? Its susposed to be a 3010 clamping force, but my act stage 1 bit alot harder? Let me know what you guys think, last nights 60 foots were dissapointing. Also how should I go about changing my two step back to 5k which seemed to hold the power a bit better. 4k boggd horrible. Thanks
If by Exedy Stage 2, you mean the 4-puck cerametallic, then that thing should grab like a ****. I rocked out with mine and launched off the 6k 2-step constantly. I first dragged it at 150 miles. 5k is too low, and 4k WAYYYYY too low. 6k is just right, but you can't slip it too long.
I dont have THAT much power either?
Well, no, if you try to slip it longer, then that makes it more prone to full slippage. If you're engaging quickly after the initial slip, then it should grab hard as hell.
When you mention engagement being different than the ACT, do you mean the engagement point, or how it feels? If your engagement point is off, then you just need to adjust the clutch pedal rod. If you have the pedal adjusted to where it engages too high, then it will be more likely to slip due to not having full contact.
Raptord
21
Mar 2, 2016 07:42 AM
flyinmonkey101
Sep 20, 2012 12:47 PM
Massevo8
30
Jul 18, 2005 05:51 PM
Car should have 11.80s in it, launch feels better than ever.
