300whp 12.2
300whp on what dyno? If a Dynojet, then that's about as good as it gets for 300whp, although that means the 4 is probably pretty light.
When I was at ~300whp (Dynojet), I ran 12.26 @ 110.0 also on a base flash. Best I could do with only one try.
According to Atlantic Motorsports dyno (old tune) I had 306whp and 280 some odd torque I ran a 12.2@ 112(On 93Pump). Full weight minus trunk weight. So its possible. Time in sig.
i was pretty happy with the run my gear changes were good,going to run at next meet on same power and see if i can go any quicker the car is very light i'd say around 3100ish pounds including me,then its in for good tune and high boost hoping to do a decent 11
My race weight until now is 3500-3510 pounds with driver with 1/4 tank... Best pumpgas time on that is 12.1 @ 114.2... What spec EVOs you have there? I assume the JDM version which is lighter than ours...
funy you hould say that reaction time was .440 wit perfect reaction time being .400
when i did the 12.2 i'd hardly driven the car and hadnt raced at the strip in it i used to be prettty good down the strip think ive got it back now
if anyone can help im after an ignition amplifier,hks cams and cam gears i cant post on the for sale section so cant post a wanted thread could someone post one for me?
hoping to dip into the lower half of 11s in the coming months
David Buschur
22
Nov 9, 2010 06:56 AM
3gEclipseTurbo
May 20, 2010 01:59 PM
