Hit the track again >.<
Old Oct 29, 2007 | 05:21 PM
mcwop23's Avatar
your 1/8th mile should be about 88-90mph, something is wrong early on
Old Oct 29, 2007 | 05:42 PM
homiusang's Avatar
Originally Posted by nikkadanny
i was shifting at 7500
heres the vid
track
Try shifting at ~7000 and hold out on 4th gear cross the line...You might be able to gain 1 0r 2 mph
Old Oct 29, 2007 | 08:25 PM
DSMEVOLUTION's Avatar
What type of clutch are you running?
Old Oct 29, 2007 | 08:27 PM
nikkadanny's Avatar
stock clutch
Old Oct 29, 2007 | 08:29 PM
nikkadanny's Avatar
i crossed the finish line in 4th gear
Old Oct 29, 2007 | 08:30 PM
hellcat's Avatar
Originally Posted by mcwop23
trap should be a lot higher
Exactly what I was going to say..I hit 108 mph with test pipe, downpipe, MBC and a tune, full weight and half a tank of gas at 22 psi. On the other hand I ran a 13.0 on that run with a 1.8 60 ft.
Old Feb 23, 2008 | 04:52 PM
nikkadanny's Avatar
new times in first post >.<
Old Feb 25, 2008 | 04:13 PM
Tarmacisback69's Avatar
u should be running 12.2-12.5 upgrade the clutch and lose some of the weight on the car.
Old Feb 25, 2008 | 09:16 PM
nikkadanny's Avatar
yea thats what i was thinking, the clutch is prolly making run slow times
Old Feb 25, 2008 | 09:30 PM
evohang's Avatar
Or not that then you might have a boost leak. Check up on that it could be a prob.
Old Feb 25, 2008 | 09:35 PM
nikkadanny's Avatar
i usually check on that once every 2 weeks, but boost is holding fine 23psi drops to 20psi by redline
TurbotrixRacing
Oct 29, 2008 01:15 PM
BostonEvo
Oct 4, 2007 09:10 AM
EVIL_EVO_VIII
Nov 14, 2006 10:51 AM
HIGH REV
Nov 3, 2003 07:33 AM
EVOLUTION/RC51
Sep 18, 2003 07:01 PM
