11s on pump gas 93oct!!
Old Dec 11, 2007 | 05:38 AM
  #61
EVOB23's Avatar
Don't make the mistake of getting an act now. You got an evo so you have to spend the money. Aight. I'll see you out there in a couple of months when Bella is ready. LMAO!
Old Dec 11, 2007 | 11:59 AM
  #62
Luis@TTP's Avatar
Originally Posted by EVOB23
Don't make the mistake of being an act now. You got an evo so you have to spend the money. Aight. I'll see you out there in a couple of months when Bella is ready. LMAO!
melvin man when is bella (your car) lol going to be ready whats left to put back toghther
Old Dec 12, 2007 | 04:00 PM
  #63
EVOB23's Avatar
Really bro its just money. I aint got deep pockets like my dad. Need to get the turbo which its a ******* for now intake manifold and fuel pumps and lines. We also have to throw in the motor. I'm hoping a good contender. LOL. If I don't blow it up.(CAUSE BOOST IS FREE) So after the holidays. Maybe my dad Will be a good guy and throw in some money.
Old Dec 12, 2007 | 04:34 PM
  #64
TTP Engineering's Avatar
No, that is nowhere close to average of what you see on the West Coast. I doubt you've EVER seen an Evo run 11.7 or 11.8 with only 113mph traps, so there's no chance you see that on average. Most people running 11.7-11.8s are trapping 117+. Of course, this is Oscar, so his driving is great, but the traps do indicate some knock on the top-end. 360+whp should be 115-116mph traps, especially with the weight reduction and no wing, but the traps may be affected by top-end knock or by extremely low tire pressure. The ETs are great, so the power numbers look right, but the traps are off for a currently unknown reason.
Come on back here when you have some facts to share with the forum. Otherwise, please keep your factless analysis out of this thread. When you can share datalogs on these drag runs indicating knocksums, please come share it here. Otherwise your just blowing hot air as usual.
Aren't you trapping 12.0X @ 113mph on meth injection, 30psi and cams with a Dynoflash tune BTW?
Old Dec 12, 2007 | 04:45 PM
  #65
Luis@TTP's Avatar
yea i hear you man i hope you get it done soon would like to see you out there at the track with me for next year.
Old Dec 12, 2007 | 05:44 PM
  #66
Nad1370's Avatar
I would also suspect clutch slippage on the NLTS 3rd to 4th.
360whp + taller tires + high boost = higher load stress on a stock clutch.
But only the driver can confirm this.
Knockng up top is also a possibility. Wished the run was logged.
Otherwise...Great driving. Nice times.
Old Dec 12, 2007 | 05:49 PM
  #67
This car is not equipped with NLTS. It is not needed and a bandaid for subpar driving skill. Sorry to say it.
Old Dec 12, 2007 | 06:15 PM
  #68
Nad1370's Avatar
Got it.
RACEMAN did state he POWERshifts it. ( Gas pedal on the floor, maybe half throttle, between shifts )
So wouldn't that be a worse load on the stock clutch while shifting?
Old Dec 12, 2007 | 06:24 PM
  #69
Worse load? The tune is more catered to this type of driving style from a technical standpoint. That is all I can really state about that.
Old Dec 13, 2007 | 08:01 AM
  #70
9sec9's Avatar
Every time someone complains about 'low mph' vs the et's, It seems they have to be reminded that IX's have different gears than VIII's and the mph will be lower. That is no reflection on the tune or performance. It's just a fact. OKIX's car was ridiculed for 'low mph' and as the et's kept getting lower, I didn't hear it so much. Posters need to consider all of the facts and how they relate to the performance of the car. The ET is the most important fact. period.
Old Dec 13, 2007 | 03:53 PM
  #71
Nad1370's Avatar
Good point.
Although he is also running a slightly taller tire at 245-45-17.
Don't know if it should matter ( I'm no mathematician ) but 1/2" more diameter would help offset the 8's 1.03 vs 9's 1.09 gearing (4th).
By no means I'm not knocking the ET or mph. This actually give me hope to cut my own times even more with some real FAST azs shifting. But that will never happen.
Old Dec 13, 2007 | 07:18 PM
  #72
kouzman's Avatar
Originally Posted by Nad1370
Good point.
It definitely helps! with the taller tire at the same rpm he gets higher speed, i think 2mph at the same rpm...
Riding the car in fourth gear for the trap it gets it out of the fat powerband sooner than the longer gearing of the VIII, thus actually having less power, thus explaining the low traps... a fourth gear from the EVO VIII will solve this problem...
Old Dec 13, 2007 | 07:23 PM
  #73
EVIL_EVO_VIII's Avatar
ETs are important but mph is what determines the true power of the car
I dont see how really that is when i have seen other members here with Evo IXs do 11.8-11.7@116+ not any different than my car.. You ran 12.14@114.2, higher trap than mine, my car trapped 113 and it went 11.7, it doesnt make sense, something is happening somewhere. The taller tires from what i have read actually help with mph if im not mistaken
Old Dec 13, 2007 | 07:42 PM
  #74
kouzman's Avatar
The taller tires DEF help.
I am really curious to see that the issue is but to tell you the truth i mostly believe is slippage... i said something before on a previous post. 4th gear higher load, already heated up clutch from launch, thus slight slippage up top which keeps traps low...
last time i ran the car decent pass over pass the traps instead of going up as i was tuning on racegas they were going down or staying the same, but after each pass i could smell the clutch and finally at the end the car was slipping like an automatic!!! Of course 0 knock and everything was perfect...
Old Dec 13, 2007 | 07:53 PM
  #75
Well the car trapped 113 on the 1st pass also.. The trap was 113 on all the passes. Not sure if it was the clutch.. going to Scott@ ttp tomorrow to have him log the car and see what the af is and if theres any knock on the top end
