Went to the track
Old Aug 29, 2008 | 09:49 AM
supercharged's Avatar
Went to the track
Well i went last night and ran 12.42@110mph with a 1.67 60 foot. Now the week before i went a 12.46@110 with a 1.76 60 foot. Does it seem my e.t. is high for my mph. Now when i ran my mustang a few years ago i went 11.7@112 with a 1.6 60 foot or is this the difference between a 4 cyl turbo to a supercharged v8.
Old Aug 29, 2008 | 09:55 AM
joseph k's Avatar
et is a bit high for the trap speed post up all the info on the slip
Old Aug 29, 2008 | 09:56 AM
Warrtalon's Avatar
11.7 @ 112 is not normal and is not even really possibly on a 1.6 60' unless you had an automatic. It's more likely that your mph was around 115-116 but only 112 on that particular run...again, unless it was automatic.
12.46 @ 110 on a 1.76 is good. 12.42 @ 110 on a 1.67 is not that good - shows slow shifting. My comparison is that with stg1 mods and 93oct on a base Dynoflash (not custom), I ran 12.26 @ 110.0 with a 1.66 60'.
Old Aug 29, 2008 | 10:10 AM
I'll post up the rest of the info when i get home
my mustang was a 5-speed 302 with a vortech s-trim. After we messed around with it a little we got it down to 10.86@126 w/ 1.49 60ft
I guess practice makes perfect. This was only the 4th time taking it to the track. Its alot different from the mustang to the evo
Old Aug 29, 2008 | 10:22 AM
Warrtalon's Avatar
Yes, but even that is nowhere close to an 11.7 @ 112 on a 1.6 60'. Think of that 10.8 as an 11.8 @ 116. The 11.7 @ 112 was an anomaly that probably has an explanation but not without more data. It's not worth using as a reference in this case.
Old Aug 29, 2008 | 10:52 AM
ok i see what you are saying maybe the mustang was making all the e.t. in the 1/8 and not the mph up top do to the tune wasn't right because that was right after the s-trim on and doing some test passes
Old Aug 29, 2008 | 11:05 AM
4kinboost's Avatar
tq and weight may be a major factor as well.
What tire were you running?
How much did the mustang weigh?
Ever dyno it? What did the tq graph look like?
What gears were you running? 4.10,3.55,3.73,3.08?
I hope freddy302 can chime in with some of his mustang #'s, they'll knock your socks off!!!
Old Aug 29, 2008 | 11:12 AM
Tire was 26x10.5 MT ET Drag
Weight was around 2,900
Never on a dyno. Guessing somewhere around 500hp
Gears were 3.73
Base_model
Jun 26, 2011 09:17 PM
KS_Evo9
27
Nov 21, 2007 09:56 AM
Booztd 3
Aug 14, 2006 09:04 PM
NIevo
Jun 25, 2006 08:20 PM
yelo3
Mar 29, 2006 09:14 PM
