12.2 at 108mph help
Old Oct 5, 2008 | 09:23 PM
gone2pimp's Avatar
yeah i was hoping to break in to 11s. well i just ordered a 18psi actuator. i hope this will help with my boost taper. i wish wartalon could give me some pointers.
Old Oct 6, 2008 | 08:18 AM
gone2pimp's Avatar
bump for more help.. gonna go to tracks again in a few weeks before they close
Old Oct 6, 2008 | 08:23 AM
inco9nito99's Avatar
Drop Advan tyre pressure to around 25psi all around, raise two-step to 6k (based on what clutch you're on and how much you spin/bog) and run 100% meth instead of 50/50 mix. At 29psi you should be trapping near 118-119. Your first run was good for a 12.0 if you could cut your 60' down to around a 1.6.
ps. what are your afr? timing?
Old Oct 6, 2008 | 09:28 AM
gone2pimp's Avatar
I am on ACT 6puck clutch. my afr is 12.2 across the board. will running 100 % meth change my afr alot? also does it mean i can add more timing ? Next i will drop tire pressure to 25psi
Old Oct 6, 2008 | 07:06 PM
Nad1370's Avatar
You should be trapping higher than 113 with your mods on your evo9.
Did you log any data on your runs ? Maybe your pulling timing up top.
Do you have an MR?
What rpms are you shifting at?
Stock rev limit is at 7600. Did you set it lower to 7500?
You stated your self-tuned but I see you have Kuniiizzzeee Dial-in.
Play around with tire pressures. All season tires usually hook up better since the sidewalls allow them to flex more than summer tires.
Cut a lower 1.7x or even a high 1.6x and you'll be knocking at 11's.
Old Oct 6, 2008 | 09:12 PM
gone2pimp's Avatar
Do you have an MR?
yeah i have pump gas tune from Kunel. when i got the Meth kit i was learning the ecuflash stuff so started tuning my own car. I did drop my rev limit because i wasn't planing on shifting any higher then 7500rpm. i did log one of my runs but don't remember which run it was. i have a video if that helps. http://www.youtube.com/watch?v=3Y4TP7MRO8Y
yes i do have an MR with the six speed does that make a different .
Old Oct 6, 2008 | 09:20 PM
gone2pimp's Avatar
Also i forgot.. i was shifting around 7200-7300 rpms
Old Oct 7, 2008 | 07:39 AM
You're running a bit lean IMHO; yes it'll affect your afr noticeably now if you toss in 100% meth.
1.) Richen it up to 11.8-12.0 with 100% meth and bump timing, (on your IX you should be able to run ~18 degrees at 30psi.
2.) For sure you will need to raise your limiter because with the IX/6speed gearing you'll be bouncing off the limiter prior to crossing the 1320 marker.
3.) Drop tyre pressure and play with the two-step to find the sweet spot between bogging and spinning; try between 5750-6200rpms.
Old Oct 7, 2008 | 08:56 AM
gone2pimp's Avatar
Thanks inco9nito99 your a great help. he is a great tuner. Yeah im just gonna throw in 100 meth and bump timing alil. Thanks alot to everyone with there insight. I will post up new times after i go to GLD again.
Old Oct 7, 2008 | 09:05 AM
lol you dork I AM Kunal.
Old Oct 7, 2008 | 05:14 PM
EvoJoeIX's Avatar
your not gonna see that much of an increase from 50/50 to 100% meth....
id just keep it at 50/50 and work on your driving...
Old Oct 7, 2008 | 05:25 PM
gone2pimp's Avatar
I know buddy.. i meant to compliment you on your tuning skills lol.. I am gonna wait till i get the 18psi actuator be for i retune.. But your pump gas tune was awesome
Old Oct 7, 2008 | 07:15 PM
Carloverx's Avatar
Here are some pointers. Immediately stop trying to make more hp or adjust the setup. Your car could have run an 11.9 with better driving. You're probably going to break something trying too hard when you just need some more practice.
I get the feeling wartalon would agree..
Old Oct 7, 2008 | 07:25 PM
IEXCELR8's Avatar
lower tire pressure to 26 psi front 28 rear
run #1 mph should be 114.XXX.
Old Oct 7, 2008 | 07:43 PM
gone2pimp's Avatar
Wheres Wartalon when you need him.. lol .. Ok i already got the 18 psi actuator on its way to my house so just gonna install it and tweak my tune alil and drop the tire pressure .
nikkadanny
Feb 25, 2008 09:35 PM
AlwaysinBoost
Dec 10, 2006 06:35 AM
03redtype-s
Nov 20, 2006 01:08 PM
BigAeVo
Jun 18, 2006 02:16 PM
LIFER
Oct 5, 2005 02:01 PM
