How to run mid-low 11's....
Old Sep 23, 2009 | 06:16 PM
  #241
Jack_of_Trades's Avatar
Originally Posted by Most-Wanted
I'm not sure about the speed sensor affecting it. If I recall correctly it operates off the switch on the clutch pedal. If it didnt then you could catch the two step without the clutch and it doesnt do that. The clutch has to go in to catch the two step...
drizzydrake-Thanks. It will be very soon.
I'm pretty sure that if you were parked, had it in neutral with your foot off the clutch, it'll hit the 2-step limit. So its not the switch IMO. I haven't hooked up the clutch pedal switch in my Mirage yet so I can't go confirm this,sorry.
Old Sep 23, 2009 | 06:18 PM
  #242
ianm12's Avatar
Iff you try hitting the two step without the clutch it won't work.
Also, if you aren't stopped it won't work. I.e. if you are rolling just a little bit. I think you need to be in first also but I know that you have to have the clutch in.
Old Sep 23, 2009 | 06:26 PM
  #243
Most-Wanted's Avatar
Yeah I know it wont work without the clutch pedal depressed. It must be in. When I was adjusting my pedal I bent the tab with the switch. When I went to hit the 2 step nothing. I almost shat myself when it went to 8k LOL.. But I also believe the speed sensor is also incorporated. It would have to be because if you were cruising and built rpms it would two step at 6500 LOL.. So they both take part in the equation...
Old Sep 23, 2009 | 06:55 PM
  #244
Macaroni's Avatar
IIRC, you can adjust the speed to which it engages/disengages through the ecu. Like anything over 7 mph and it won't work or something like that.
Old Sep 24, 2009 | 03:40 AM
  #245
blackdemon's Avatar
Old Sep 25, 2009 | 03:54 AM
  #246
blackdemon's Avatar
I found out after looking at my logs that i had a little issue on that 12.0 run. Ill go back to the track next week after we fix this.
Old Sep 28, 2009 | 09:11 AM
  #247
blackdemon's Avatar
bump
Old Sep 29, 2009 | 02:48 PM
  #248
ssg_petty_210's Avatar
That is pretty fast. I just got done talking to the guy who will be tuning my car. Here is a question. With the mods i have posted, what do you think with a good tune id run in a 1/4?
GReddy TBE, KN Intake, ETS Intercooler, Walbro 255 fuel pump, AMS boost controller, Eibach springs (not for power purpose) Custom tune.
Old Sep 29, 2009 | 03:12 PM
  #249
Hard to say without more info. Lots of variables. Weight, type of tire, type of clutch, driver ability, etc... Car should go 11's depending on the tune.
Old Sep 29, 2009 | 03:14 PM
  #250
meltdown's Avatar
Most Wanted -
Ryu-
At what RPM's does ur car drop too when you launch?
Most Wanted if you remember I'm getting a good 60', 1.64, but the car drops to 3500 rpm and is hurting my 1/8 mile. You said I need to slip it a lil more to keep the rpm's up and I'm just wondering what the most it should drop to.
Old Sep 29, 2009 | 03:17 PM
  #251
meltdown's Avatar
and have you had any experience with the ACT HD street clutch (organic). I'm wondering how well it will hold up to slipping it?
Old Sep 29, 2009 | 03:29 PM
  #252
stock clutch, stock tranny and etc. mods are as i posted. I am a pretty good driver, i have been dragging for quite some time. on 93 octane also btw
Old Sep 29, 2009 | 04:46 PM
  #253
blackdemon's Avatar
on my 1.73 60ft 2 step set at 5500rpm the rpm droped to 3785rpm. Not sure if i should have sliped it more.
Old Sep 29, 2009 | 05:06 PM
  #254
i will be able to run it once i get back to the states from this hell hole lol. but just wanna know what times people are running with these mods. stock weight, stock clutch, just the mods i have posted up. I will most likely have a few more parts to add by the time i go to get the car tuned.
Old Sep 30, 2009 | 12:28 PM
  #255
blackdemon's Avatar
what gear are you in by the 1/8th mile?
