How to run mid-low 11's....
I just want to say something that needs to be put out there. The only other person I have known to "care about the little people" that would be considered a big dog is Shep. I will go ahead and apologize if there are others out there that do the same but I have not yet experienced it enough to leave an impression on me like this.
What I'm trying to say is, it really means a lot when someone who is practically considered one of the big boys steps back and takes the time to help out the little guys. Ones who are still stock setup or just bolt ons. I want to thank you again for this thread and for helping us out!
Again I would like to apologize if there are other companies who do the same but I have not mentioned. My first experience with this was John Shepherd and now you. I don't doubt there are many other guys out there or big companies who treat their customers the same or try to reach out and help everyone but these are just the guys I have noticed.
Thanks for all the tips. I dont post too much bit I do read and learn.
Looking forward to taking my 8 RS to the track. It is almost ready.
bren
Question for you.... would I be better off trying to build MORE boost at a lower engine speed or run less boost at a higher engine speed for the launch? Previously I've done 10psi from 7200 and ran a 1.7 I did 10psi for 7.8k and it did a 1.6
What I'm thinking is that I'm getting a good 60', but the way I'm doing it is hurting my 330 time. My thought out solution was to run 20psi on the line at a lower RPM like 6k and not slip the clutch as much.
Any input on my thoughts? Also... I was able to get the spool (anti-lag) between the shifts with a lot of timing retard and more fuel
Most wanted: Here are my passes from yesterday. Starting from first pass to last. Tell me what you see. 2 step is set at 5500 anything higher i spin much more than what i already spin. #1048 on the slip
you are right there. Its the 60' that is hurting you. If you are spinning with the 2 step at 5500 there is another factor. Whether it be a cold surface, poor track prep, running through water without a burnout, letting the clutch out to fast, tire pressure too high, etc. 115 mph is good for 11.50's no problem. Just work through it. Start with the little things and make small changes. Make notes of your 1-2 shift also. A good idea if you can get it done is to buy the Buschur camera mount and video the run. Then you can go home and see whats going on. I have learned alot from watching my videos.
HMMM, funny you say that. This was back in April of 2006
Way before I knew anything about removing bumper supports etc. This was a basic Buschur stge 2 in a full weight GSR. Only thing removed was tire junk and passenger seat. This was my post........now that the car is so perfectly dialed in thanks to Buschur Racing and Dynoflash, it has given me the opportunity to better myself without paying so much attention to the car. Last week I had a .004 reaction time and tonight I got two perfect lights. One was a .002 and the other was a .000. Here's what the slip looked like.
r/t .000
60' 1.623
330' 4.812
1/8 7.500
mph 89.96
1000' 9.801
1/4 11.746
mph 113.85
I've done hundreds of mid 11 sec passes with mph around 113-117. Here is from another night. Keep in mind this car had stock TB, stock intercooler, stock cams, stock head, stock everything.
r/t .280
60' 1.655
330' 4.815
1/8 7.477
mph 90.86
1000 9.774
1/4 11.713
mph 114.32
r/t .004
60' 1.655
330' data missing
1/8 7.512
mph 90.58
1000 data missing
1/4 11.758
mph 114.32
And for your viewing pleasure
http://videos.streetfire.net/video/7...6615A316EE.htm
Yeah, it takes time. But once you get it down it will be awesome and consistent. Thats why I am trying to help out. I have hundreds of passes and this is just what seems to work best for me. Obviously every car is different , mod path differences, and driver ability. But its a starting point.
I've also heard from a few people that i should set my launch rpm to the rpm that I bog down to.
Ive seen you meantion a few times that its all in "how you let the cluth out". I was wondering if this holds true as well to people running Twin disks? I havent really had all that much sucess finding a proper way to slip the clutch ever since I swapped over to a twin, it seems to either just be engaged or its not, which has been causing me to either spin horribly off the line or bog instantly from having to preform the 1-2 shift far too early.
Is there a recommended way you would let out a twin disk most wanted?
I agree with you for the average guy though. 115 is usually good for very high 11's for most.
