How to run mid-low 11's....
Buy Zex part number 82021 and a Walbro pump. Spend 1.5 hours installing. Adjust non-nitrous fuel map to accomodate the pump to around 11.5:1 AFR. Install 67 nitrous jet and 23 fuel jet, spray away. 120+ traps all day long missing gears and pulling a boat, pump gas, stock car. Run the stock timing map.
$600 total.
$600 total.
Most wanted do you think I would be able to break into the 11s with my setup? Or is it wishfull thinking. I know it should hit a 12 flat but not sure about 11s
Good thread. Im ready to hit the track after your advice. Last year I was at 344 WHP on the dynojet with 319WTQ and ran a 12.5 at 112mph with a 1.783 60ft as my best. Now Im running meth with 30psi. 380WHP and 391WTQ. I was just hoping to break into the 11s with this but it sounds like I could be in the mid to low 11s. My 2step is set to 5800 though. I am also on the stock clutch. My 12.5 was with 30-35psi in the tires also. This time I will set them to 18 and see what happens.
As long as the power is made it should do it. Regardless of weight I would start of launching around 6400 and adjust from there since your friend is able to make changes for you...
You also need to adjust your two step to the as mentioned 6400... Let us know...
Thanks. And yes your mod list is nice. Actually very nice right down to the BBS wheels. A little mixed and matched, but the essentials are there and you have chosen the top 3
As long as the power is made it should do it. Regardless of weight I would start of launching around 6400 and adjust from there since your friend is able to make changes for you...As far as the mods go. I usually don't post much just read a lot, I've done my research and these for the most part these are some of the best parts out there.
Yes, I too am a huge fan of buschur (this is reflected in my own car). They really do a lot of testing / weighing and write ups. Their cars really speak for themselves.
Once I make a few passes in the car I will be sure to report back my findings!
Frankly, it was rather an amazing accomplishment and a real testament to the performance of Buschur Parts
When I custom ROAD tuned this car it was amung the very first IX Evos that I reflash tuned. This was well before the advent of ecu flash. At the time I was using a crude hex editor to adjust the maps and there was zero tech support beyond trial and error. There was no one to copy - nothing to review and no tech support of any kind. It was pure looking at patterns and finding maps by knowing what they look like.
I remember having to remove the ecu for each reflash and then replug it into the car and also having to use a matco scan tool as my data logger.
Before ecu flash and all the dozens of tuners specializing in this, I used to travel all over the USA street tuning Evos with the same methods with hundreds of cars tuned with the same crude and simplistic methods.
The tune up coinsisted of a Buschur Flash combined with road tuning for a simgle PUMP gas map that was then run on 100 octane race gas with the boost turned up a bit.
I agree that the whp was prob in the 370 - 380 range and again very good considering at the time it was the fastest and quickest stock turbo IX and also considering that the tuning was at its infancy.
The reality is that none of it would have been possible without your great driving.
I am however, very proud of the way my tuning held up at the track event that day and for many more miles of driving.
It should. Are you on an 8 turbo?? Sorry if I missed that you stated somewhere what you had. Its hard to keep up with everyone's set ups... Clutch is not going to like you so be forewarned
You also need to adjust your two step to the as mentioned 6400... Let us know...Thanks for your help
Shifts should be done according to your dyno sheet, but generally fall somewhere around 7200-7400. Tire pressure is a biggie. Your mod list is all over the place, but the numbers look good. Just not sure why the et is low. Just practice the shifts and do these few things and let us know how it turns out.
someone pm'd me today on getting ready to go to the track and needed some help. I was cleaning out my inbox and got carried away and deleted it by accident. Please pm me again. Sorry...
I just want to say something that needs to be put out there. The only other person I have known to "care about the little people" that would be considered a big dog is Shep. I will go ahead and apologize if there are others out there that do the same but I have not yet experienced it enough to leave an impression on me like this.
What I'm trying to say is, it really means a lot when someone who is practically considered one of the big boys steps back and takes the time to help out the little guys. Ones who are still stock setup or just bolt ons. I want to thank you again for this thread and for helping us out!
Again I would like to apologize if there are other companies who do the same but I have not mentioned. My first experience with this was John Shepherd and now you. I don't doubt there are many other guys out there or big companies who treat their customers the same or try to reach out and help everyone but these are just the guys I have noticed.
Well, it wasn't long ago I was sitting where most are at looking for help to go faster. I was amazed at how many people wouldn't even give me the littlest of help. Even the simple stuff like not telling me what seat rail to use when they have the same exact seats. I had to do most of it on my own and I thought it didnt need to be that hard. Thats why I started this thread. To help people out and try to keep the cost down for them. In all honesty, I much rather go to the track and have 10 fast evo's there then just mine. It's good for the entire community. It's important to not lose sight of the fun factor as I almost did recently. That was another big reason for this thread. I'm glad you like the thread and hopefully it has helped you in one way or another. Thanks for taking the time to say thanks. I am always willing to try and help out.
