How to run mid-low 11's....
Old Sep 19, 2009 | 08:25 AM
  #196
Most-Wanted's Avatar
Originally Posted by foxmr
so i went to the track last night and first pass spun first and into second for a 12.9 with a 2.2 60 so lowered tire pressure to 30 psi and did a spin through water ran a 12.8 but got some bad wheel hop on the launch and had to back out quite a bit. sooooo my question is what do you do to stop wheel hop i have bc br coilovers and 255 azenis. i know to soften up the rear for weight transfer and i did but my third pass i cut a 1.8 60 ft and still wheel hopped pretty bad and blew the licp rite after 1/8th mile and still ran a 12.8.
thanks josh
Tire pressure is way too high and slip the clutch slightly to revs up. That should help reduce wheel hop. TP should be around 21 psi....
Old Sep 19, 2009 | 08:38 AM
  #197
Jack_of_Trades's Avatar
90% of guys tend to end up in the 20-22psi range with their tire pressure at the track. Some have luck with higher pressures but most do not, like yourself.
Old Sep 19, 2009 | 08:50 AM
  #198
blackdemon's Avatar
When i cut the 1.75 60ft tire preassure was 18-20psi
Old Sep 19, 2009 | 08:55 AM
  #199
wizzo 8's Avatar
I was at 20-21 psi and I did back to back 1.57 60fts after a 1.8 with 30psi. Even though its all wheel drive tire psi still makes a big difference.
Old Sep 19, 2009 | 09:04 AM
  #200
So does a nice suspension with the proper spring rates, adjustable ride height to preload the wheels that need it and also struts that allow you to adjust the rebound rate. Not to mention camber tweaking, gotta keep those babies on the ground with a flat contact patch while launching and distributing the weight more equally to the front and back. Ask Dynoflash Al, this was his first year with a tuned suspension at the DSM shootout and his results speak for themselves.
Old Sep 19, 2009 | 09:10 AM
  #201
wizzo 8's Avatar
Yes that also makes a big difference. I was just saying tire psi makes a big difference. Well it did for me at least. I have ran my car at the track maybe 20-30 times with 1.7-1.9 60fts. Then I saw this thread and lowered my tire psi to 20 and right away 2 back to back 1.57 60fts.
Old Sep 19, 2009 | 09:23 AM
  #202
blackdemon's Avatar
what tires do you have? Where is your 2 step set at? and how much boost are you building on your 2 step? Im still on stock suspension so i dont know how much better i can get my 60ft
Old Sep 19, 2009 | 09:25 AM
  #203
plenty of people do amazing 60' times with the stock suspension (I hate them all! lol) but improving the suspension down the road will just make things even better. I don't recommend anyone using Nexen tires though......terrible tire for the track.
Old Sep 19, 2009 | 09:29 AM
  #204
blackdemon's Avatar
I have the falken azenis with 255 width not the best tire for the drag strip but they are great on the road.
Old Sep 19, 2009 | 09:34 AM
  #205
wizzo 8's Avatar
I have Michelin PS2s. 6k 2 step and around 8-10psi. Im on the stock suspension also. My tires probably have a lot to do with it also.
Old Sep 19, 2009 | 10:03 AM
  #206
EVOVIII200's Avatar
I agree, Indy evo lowered his pressure before he ran his 11.84. before the pressure adjust he ran 11.9 . even after his good run it was going to be an 11.7 coming, i will try it next time we are at the track.
Old Sep 19, 2009 | 10:18 AM
  #207
foxmr's Avatar
ok thanks i will drop to 20 psi all around next trip out and hopefully get a 1.5 60 but thats rough with a 6 speed the one to two is so quick and thats what makes my 60 times as for suspension stiffer up front and a little softer in the rear?
Old Sep 19, 2009 | 02:11 PM
  #208
I was on stock suspension w/ tein s tech's when I went 1.5's also.
Old Sep 20, 2009 | 07:51 PM
  #209
blackdemon's Avatar
Ran today at island dragway 20psi tire preassure. Spun so much the car went sideways. Still managed a 1.73 60ft. Maybe its my falken azenis tires. im going to try drag radials or all season tires to see if i get more grip
Old Sep 20, 2009 | 09:23 PM
  #210
Macaroni's Avatar
My buddy pulled a 1.59 on General Exlaim UHP's today! Pretty crazy for a all-season tire if you ask me!
