Other 16" wheels that will fit Evo
Old Jun 29, 2011 | 01:16 PM
  #46
ta ace's Avatar
SLIPSTREAMS the only rota's that work?
http://cgi.ebay.com/ebaymotors/16-RO...Q5fAccessories
OR
http://cgi.ebay.com/ebaymotors/1-ROT...Q5fAccessories
WOULD BE NICE
Old Jun 29, 2011 | 01:46 PM
  #47
rodent's Avatar
I'm sure other models may work with less wheel spacing such as the Subzero and Grid. I'd stick with a lighter model. Slipstream is the lightest but only by a pound.
16x7 Rota Slipstreams = 13.5lb
16x7 Rota R-spec = 14.5
16x7 Rota Subzero = 14.5
16x7 Rota Grid = 15 lbs
16x7 Rota Circuit 8 = 15.5
16x7 Rota GT3's = 17 lbs
16x7 Rota MSR = 17.2
Unfortunately I don't have the resources to try other wheels that may or may not work like the RPF1.
Old Jun 29, 2011 | 01:57 PM
  #48
ta ace's Avatar
that boost is a +45 wheel which would help w/ clearance issues im sure
Old Jun 29, 2011 | 03:06 PM
  #49
rodent's Avatar
Looks to be 15.5 lbs.
http://www.racinglab.com/rota-boost-0001.html
And yeah, having a +45 with a 20mm spacer would be exactly the same as factory on the outer edge.
http://www.1010tires.com/wheeloffsetcalculator.asp
The question is will the spokes clear the calipers?
Old Jun 29, 2011 | 03:32 PM
  #50
ta ace's Avatar
I WOULD only assume w/ the 20mm spacer +40 would be better then now understanding the placement
17431 26x 9.50-16 hoosier QTP anyone run those?
Old Jun 29, 2011 | 03:50 PM
  #51
rodent's Avatar
I have that QTP tire but have yet to run them. Many have claimed 1.4 60 foots.
Old Jun 30, 2011 | 06:33 AM
  #52
ta ace's Avatar
9.5 wide tire what rims your using for this? the 16x7?
Old Jun 30, 2011 | 07:41 AM
  #53
rodent's Avatar
Yep.
These are what I bought and the best price I found-
http://www.summitracing.com/parts/HOO-17431
Old Jul 1, 2011 | 10:28 AM
  #54
rodent's Avatar
Picture showing where the lighter FD wheels hit with 20mm spacers:
Old Jul 1, 2011 | 12:35 PM
  #55
rodent's Avatar
Just installed the new longer ARP studs in the rear. What a BIOTCH! Had to remove the entire hub bearing assembly along with the rotor and caliper and use a press to get them out/in. Wasn't sure if the hub bearing was going to come out or not.
Did a total redneck move and used my cheap homemade slide hammer that I normally use for my tcase shaft removal and screwed it into the threaded holes in the the rotor which was held on by the wheel nuts.
Old Jul 1, 2011 | 12:41 PM
  #56
Donkeypuncher's Avatar
Did you do this in the rear just so the wheels would be even with the front? I understand the rear is not required. i am doing the same today but only doing fronts. I dont want to have spacers in the rear if not necessary.
Old Jul 1, 2011 | 06:03 PM
  #57
rodent's Avatar
The FD wheels will stick in 12mm and come REALLY close to the rear control arm. You don't need any spacers as long as you don't use crimp on weights. I wanted to use the ARP studs for extra strength with the spacers but stock studs are fine with the FD wheels alone.
Old Jul 2, 2011 | 09:56 PM
  #58
EvoDan2004's Avatar
i put the studs in the front and rear just because i wanted the car to look even while the stock rims are on it.
Old Jul 3, 2011 | 10:18 AM
  #59
rodent's Avatar
Also by having the long 3" studs it makes it much easier to install/remove the spacers and you can check your lug nut torque without having to take off a wheel with the bolt on spacers.
Keep in mind the FD wheels will stick out 8-10mm in the front with spacers and stick in 12mm in the back without spacers so it looks kind of odd. Not a big deal when you're racing though, just personal preference.
Old Jul 3, 2011 | 05:14 PM
  #60
Good point, I just wanted to keep weight down especially the unsprung. Still wanna show the car so maybe I'll keep some spacers on hand for the rear
