Other 16" wheels that will fit Evo
Old Jul 20, 2013 | 10:10 AM
  #91
ebp99si's Avatar
are you running a 15" wheel or a 16" wheel?
ive heard that a 16" with the right offset could clear the stock brakes
Old Jul 20, 2013 | 11:45 PM
  #92
GotWheelHop's Avatar
I don't know of any 16's that fit without spacers. Offset isn't your only foe here. If you look at FD wheels, not only do you have spoke clearance on the caliper to worry about, but the sheer size of the caliper CAN hit the barrel of the wheel as well depending on the wheel. Some wheels have a thicker barrel, and some have more space. Make sense?
Old Jul 28, 2013 | 03:45 AM
  #93
DVS_09's Avatar
Originally Posted by rodent
Picture showing where the lighter FD wheels hit with 20mm spacers:
just wanting confirmation that the one on the left is the only wheel that fits with 20mm spacers?
Old Jul 28, 2013 | 03:20 PM
  #94
s.e.a.n.'s Avatar
They both use the 20mm spacer
Old Jul 29, 2013 | 03:50 AM
  #95
DVS_09's Avatar
ok thanks but how come the picture on the right says it hits evo caliper even with the 20mm spacer?
Old Aug 3, 2013 | 11:18 AM
  #96
itsmrrizz2you's Avatar
nice setup thanks for the info
Old Aug 4, 2015 | 11:16 PM
  #97
JGNERAEVO9's Avatar
Bumping this thread want to get a set of Enkei RPF1 16x8 +38 will they clear with a 20mm spacer? Do you need spacers upfront only or back and front?
Old Feb 13, 2016 | 10:27 AM
  #98
1SlowRS's Avatar
I was wondering this to, also do you need spacers in the back as well? Or just the fronts with either set of fd wheels? I'm just wondering Bc I found a mix set 2 wheels are the heaviest version and the other 2 wheels are the lighter versions, should I run the heavier ones in the front or back
Old May 19, 2016 | 07:51 AM
  #99
rodent's Avatar
NO. Read the thread. 16" RPF1 wheels DO NOT FIT. Sorry this is late but I don't someone making the same mistake I did.
No spacers required in the back. Heavier in the front would be preferred but it doesnt really matter.
GTABurnout
Jan 12, 2019 11:50 AM
demodeakin
For Sale - Wheels / Tires
Mar 10, 2018 10:32 PM
cvnick
May 20, 2016 06:45 AM
TwinTurboM3
Apr 16, 2016 01:57 PM
poof83grt
Mar 8, 2016 04:24 AM
