11.63 @ 117.98mph evo 8
I tried couple of times.when you stage your car apply hand brake,use launch control and slowly release the clutch until you feel car wants to go.this way you preload the drive train.release the clutch and drop hand brake at the same time.
I bump the first beam, set the brake and let the clutch out slow till it wants to go...bump the second beam and just hold the clutch right at the point of engagement, and I just put it to the floor and drop the brake and come off the clutch as fast as I can...I like a pro tree much better then the three lights but each car is going to be different just need to make sure you stay in boost! I don't think ill be making any more passes this season I messed up the front diff out goofing off on wet pavement
