Shift Points...
Old Jun 30, 2004 | 11:42 AM
KazzEvo8's Avatar
Shift Points...
You read the title, now, when do you shift in which gear? With what mods?
Anyone actually done the dyno research on their mods to know where their powerband in each gear is? How about with just a stock Evo?
Thanks!
Old Jun 30, 2004 | 11:50 AM
Scot's Avatar
i know for sure my Evo ran a good bit slower trap speed by overreving it.... i was switching at 7600rpm or so and trapped at about 98mph...... switching at 7000 got me 13.409@ 102mph......totally stock
Old Jun 30, 2004 | 12:05 PM
sir lurks alot's Avatar
Is there an advantage to shifting at different points in different gears? I ran a 12.97@105 shifting at 7800k in every gear. Would I go faster maybe if I shifted sooner than that? I know torque drops significantly at higer rpms, but I would think that holding the lower gear ratio for longer would out-benefit the extra tq of a lower rpm. What do the pro's shift at? Al has as many passes as anybody, has he experimented with shift points?
Old Jun 30, 2004 | 01:28 PM
KazzEvo8's Avatar
The point here is that the optimal powerband is in a certain RPM range. The powerband can differ by gear. Shifting from a gear drops to a different RPM based on the gear ratio. Putting all of this info together, if anyone has done this amount of work, will tell the OPTIMAL shift points based on THEIR mods... that's what I'm askin' about!
Clear as mud, right? =)
Old Jul 2, 2004 | 06:53 PM
Audi2ptzero's Avatar
Thanks!
I wish I could give you some info on this one. I do all my shifting by the seat of my pants. Which means I can actually feel the power drop off. If you can do the same you will want to shift about 500-1000 rpms after that point.
This is one reason I am having issues over running my gears since my peak hp is so close to my 7800 rpm rev limiter in my A4.
When I ran smogrunners stage 1+ I shifted right around 7200 rpms.
evo8 951
Jan 20, 2011 11:57 PM
lancer2008
Lancer Tranny/Drivetrain Tech
Oct 27, 2010 06:00 PM
Lil red '03
Driving Techniques
Jul 10, 2005 11:22 AM
Hiboost
May 2, 2005 05:53 PM
2003 evo
Jun 3, 2003 04:51 PM
