Alcohol Kit and Dyno Flash
So you can basically set it when you want it to start spraying. For example if you want daily driving you can lower the boost to say 19 psi and when you want to use the alcohol you turn the boost to say 20 where the spray starts.
is this right AL?
If so how would the map be good if it is expecting the alcohol to be sprayed wouldnt this mess the tune up if you were not using the alcohol?
is this right AL?
Originally Posted by gestalt
Does this kit use a map sensor to read boost?
is this right AL?
is this right AL?
If you tune it conservatively you can use the same street tune with higher boost to make more power.
Of course the best approach for max power is to set the car up with a very agreesive tune you cant run on pump gas.
Every case needs to be exmained depending on the particular owners needs and requirements.
Originally Posted by archie001
sup al archie from miami,fl
where can i buy the "knock link" to moniter knock and or is there any other less bulky knock monitering device
www.vividracing.com
Originally Posted by Doc
Sorry if this has been covered but how much is the knock link??
99.99 sensor
16.99 female plug
www.vividracing.com
Is this basically the same kit that Dynoflash is selling? http://www.smcenterprises.com/subaru.htm
Need to get this working so I can buy my alky kit from Al....... Thanks in advance guys....
