Quote:
Or you can get a used Greddy Profec B , the first model, it is very straight forward and works great. ... and a used one you can get it for about $100.. Originally Posted by rican evo
Hallmans theway to go. Gotta have a decent boost gauge not only for going up but also for maintaining adecuate and precise boost levels. Will set you up 100 bucks, a pretty good deal if you ask me ! That's what I did...
Miguel
Miguel
good advice !Originally Posted by El Boricua
Or you can get a used Greddy Profec B , the first model, it is very straight forward and works great. ... and a used one you can get it for about $100.. That's what I did...
Miguel
Quote:
My new boost controlling flash can do the boost control up to 20 psi Originally Posted by SEVEN
I was going to get the Boost Controller later cause i dont think u need a re-tune for boost and exhaust...if i am mistaken then Al can correct me, . My car has a 20 PSI peak of boost right now...with Al tune, i just want the get rid of the boost taper
Of course for maximium control and adjustability the MBC is hard to beat
However - the ecu controlled boost control flash is stealth, simple and easy
Hey Al, do you think its gonig to make a lot of difference installing hks 264/264 with my current set up ?
Quote:
Cams are good for about 23 - 26 whp and tqOriginally Posted by rican evo
Sat May 21
10:00 - 12:00 Rafael
12:00 - 2:00 Randy
2:00 p.m. - 4:00 Omar
4:00 p.m. - 6:00 p.m. Javier
6:00 p.m. - 8:00 p.m. Losorio
8:00 p.m. - 10:00 p.m. Miguel Paulino
10:00 p.m - 12:00 midnight Gustavo Hernandez
Sunday May 22
10:00 - 12:00 noon Roberto Betancourt
12:00 - 2:00 p.m. Carlos Santana
2:00 p.m. - 4:00 p.m. Javier Ojeda
4:00 p.m. - 6:00 p.m. Marco Arocha
6:00 p.m. - 8:00 p.m. (Space open with money in hand only)
Any additional info call me
Updated
12:00 - 2:00 Randy
Sunday May 22
Updated
OK now is my turn
First of all thanks AL for taking some time and help us out making the evos here in PR kick some butt also this makes me proud because i have worked with at least 4 of the cars getting the flash and at last i can be able to see results of all the sweat,bruises,cursing
and time i have spend on them. Bolt on is what vendors say but bolt on real world is work your *** off to make it fit in my world
Second thanks to Randy for making my idea posible and getting everything worked out.
Third and important also is Rafael who is always getting me busy and for contacting Randy and letting him know about the idea.
Now lets get down to business.
Javiers car is a 2003 with:
Borla exhaust
Megan racing downpipe with B&B 3 inch cat delete
Megan racing o2 housing
Megan racing exhaust manifold
AMS MBC
Helix intake
Helix IC piping kit
255 walbro
perrin fuel rail
272 intake 264 exhaust GSC cams
Greddy type S recirc.
AFC 2
Defi d gauge FP,EGT,Boost
This is the lucky SOB
every has gone smooth since day one of mods and it beats the **** out of my car since both were almost stock.Cars runs great . I tune it a little bit with the AFC running a conservative 10.4 AFR on a LM1 Wide band
Now mines. It is a 2003 also but with a curse
ultimate racing 3 inch turbo back exhaust with cat delete.
Megan o2 housing
Megan SS manifold
Perrin fuel rail
Walbro 255
Helix intake
Greddy type s recirc.
Hyperflow FMIC
Logic performance IC pipes
Hallman MBC
272in/264 exhaust HKS cams
AFC 2
Defi BF ambers FP,EGT,Boost.
Mine is the tricky SOB .Maybe because i spend more time with others people cars and no time left for mine it has a boost problem.It hits 22 pounds hard but after 6000 rpms it start bouncing back and forth very fast from 17-19 making it loose a lot of power.I have fried my brain trying to get this issue solved with any luck.I know it looks like a boost leak but i could not find the SOB.
Maybe you can help me out.How can i make a boost leak test or how can i get this diagnose before you get here?
thats all for now AL please get back to me
. First of all thanks AL for taking some time and help us out making the evos here in PR kick some butt also this makes me proud because i have worked with at least 4 of the cars getting the flash and at last i can be able to see results of all the sweat,bruises,cursing
Borla exhaust
AMS MBC
Helix intake
Helix IC piping kit
255 walbro
perrin fuel rail
AFC 2
every has gone smooth since day one of mods and it beats the **** out of my car since both were almost stock.Cars runs great . I tune it a little bit with the AFC running a conservative 10.4 AFR on a LM1 Wide bandNow mines. It is a 2003 also but with a curse
Megan o2 housing
Megan SS manifold
Perrin fuel rail
Walbro 255
Helix intake
Hyperflow FMIC
Hallman MBC
AFC 2
Hi Al
I'm already sign up for the dynoflash in PR.
264/264 HKS cams
Injen Intake w/IC pipe
Magnaflow Ti cat back exhaust
Test pipe (unknown manuf.)
Helix Down pipe 3"
DPN Headers (will get more info)
MR bypass BOV
What other mods would you suggest.
Not a daily driven car. Solo 1 racing.
Looking for 350 whp, may be 11.5 sec 1/4 mile @115 mhp.
Never done any drag.
264/264 HKS cams
Helix Down pipe 3"
MR bypass BOV
hah and I thought I wanted a lot for drag racing ah Gustavo?
I said 11.8 @118 you want 11.5????
DAMN!
I will check on that DPN Header
DAMN!
264/264 HKS cams
Helix Down pipe 3"
MR bypass BOV
Must have - boost controller (Hallman MBC recomended) - and walbro fuel pump. Optional - Alcohol injection kitOriginally Posted by nuclearevo
Hi Al
264/264 HKS cams
Helix Down pipe 3"
MR bypass BOV
