Can I add Alky in your race tuned?(without getting retune?)
Hey Al!
You tuned me before on race map 29 psi on 114 octane. Pump on 24 psi.
Would it possible to add Alky(snow performance) on my set up without getting retune? I will still run the same boost Pump=24psi Race=29psi. I won't touch either map...
I just want to be in safe side because of the hot
weather in FL.
Thanks!
weather in FL.Thanks!
It al depends on how hard to intend to pusg that turbo
that turbo is more than capable of maxing out 1,000's with high boost
If you block is stock I would suggest 28 psi max which would equal approx 480 - 500 with the right combo
880 or so would be good for that level of power assuming you dont want to push it to 36 psi
Al
Al
So 880's?
I have Wiseco Pistons, Eagle Rods, Arp head studs and rod bolts, Clevite main and rod bearings, Ported head and valve angled job, HKS 280's (stock valvetrain) I will upgrade springs and retainers as soon as i get a new set of cams. (choices are: Jun 272's/BR cams/GSC S2's)
Don't you think im ready for 35psi+ on straight 114 octane? or should i get alky too?
scheides
124
Feb 6, 2014 02:15 PM
scheides
Jun 19, 2009 05:50 AM
Warrtalon
72
Jan 24, 2006 04:50 AM
