DynoFlash [Visit Site]
EGT Temperatures
Old May 3, 2004 | 03:14 PM
fury656's Avatar
EGT Temperatures
For all those who have some method of monitoring EGT temps I was wondering what your average temps are at load points. Any feedback from Custom or base flashes owners would be greatly appreciated. Also, Al if you have any input as to the temp range your tunes are designed not to exceed please chime in. I've read that EGT temps at load points (on boost) should not exceed 900C (1650F). Hopefully we can put together some sort of definitive reference.
Old May 3, 2004 | 03:30 PM
tama_mog's Avatar
Mine rarely gets past 800 degrees C, ,on a custom tune.
Old May 3, 2004 | 06:28 PM
phish52's Avatar
I have a base flash and my temps are about 1250 cruisin and it gets as hi as 1460, very safe!
Old May 3, 2004 | 06:31 PM
Evo_doer's Avatar
Red face
Dude Those temps are not that safe. Kind of high, and may lead to pre mature failure.
Old May 3, 2004 | 06:36 PM
evo542's Avatar
cams will significantly lower the EGT
Old May 3, 2004 | 08:43 PM
stvbreal's Avatar
He's fine, way safe. I'm running 1400 F WOT and want to get to 1550-1600.
Old May 3, 2004 | 08:45 PM
bpclements's Avatar
The general rule of thumb when it comes to egt's is not to exceed 880 C. I see 700 C when cruzing around town and 800 C on the highway. At the top of 4th I see 840 C.
Old May 3, 2004 | 09:01 PM
BJai02's Avatar
I think phish52 is refering to 1250F and 1460F.
Old May 3, 2004 | 09:11 PM
stvbreal's Avatar
Obviuosly. If he ras running 1460 C I doubt his internals could withstand it.
Old May 4, 2004 | 11:01 AM
EvolvedfromaWRX's Avatar
im sure that the stock car gets that hot while doing a 5th gear pull to 150 or so...there is no way it can stay that low at that speed...thats just in boost for too long.
Old May 4, 2004 | 12:08 PM
YEVOVIII's Avatar
I have yet to get over 600c. Even in this Texas heat at WOT through 1st 2nd 3rd and 4th I peak at around 580c. AM i runing way to rich?
Old May 4, 2004 | 12:13 PM
stvbreal's Avatar
Yeah, I'd say. Get a S-AFC and lean that sucker out some.
Old May 4, 2004 | 12:42 PM
vroomevo's Avatar
hmm...where is your egt probe located?
Old May 4, 2004 | 12:48 PM
stvbreal's Avatar
Ah, good question. I would think maybe on the downpipe explaining the reason for lower temps?
Old May 4, 2004 | 02:18 PM
YEVOVIII's Avatar
Well
THe EGT sensor is located in the 1st cylinder port of the exhaust manifold. Isnt that where it is supposed to go?
