DUAL fuel Pump
Old Sep 29, 2008 | 08:44 AM
4drboost's Avatar
DUAL fuel Pump
Anyone have recommendation on which dual fuel pump to go with? I'm currently using a single walbro and 880cc injectors w/ GT35R turbo and converting to E85. Tia
Old Sep 29, 2008 | 09:54 AM
Jim in Tucson's Avatar
I've never read any negative reviews on twin-pump set-ups. FWIW.
I'd say go with a well know EVO turner shop twin-pumper and you will be good.
Old Sep 29, 2008 | 03:30 PM
PATRICK B.'s Avatar
Yup don't think you can go wrong.
We have 3 cars going E85 2 w/ Full Blown set-ups and 1 w/ Buschur's.
Old Oct 2, 2008 | 09:20 PM
EpicEVO's Avatar
I have been using the Buschur Double pumper for over a year now with all the stock lines and it works FLAWLESSLY!!! I am very impressed with how well this setup works!! My car runs pretty consistant 10's in the 1/4mile and i daily drive the car on the street!! This dual pump makes it easy to tune in the low throttle settings while still being able to have all the fuel you need to run high boost without any problems...
Mark
Old Oct 5, 2008 | 10:47 AM
Billy@EnglishRacing's Avatar
do an in tank 255 and an inline 255, this set up will flow more then 2 intakes. Then swap in some 1200cc injectors
Old Oct 5, 2008 | 10:49 AM
purevibez's Avatar
you got lots of options man. buschur twins or full blown twins. 1000cc inj atleast now to turn up the wick on that 35r. ive seen reds max out the 1000 or dam near max out 1000's on corn.might wanna think 1200's like inneedof said.
Old Nov 5, 2008 | 02:07 AM
SpeeDeviL's Avatar
Mark
Hey Mark did you install the BR twin fuel pump yourself, if you did can you tell me where did you connect the hobb switch for the boost/vacuum source???
I installed the twin pump and everything went smothly, but I can't seem to find a good location for the hobb switch
Can you please help me
Old Nov 5, 2008 | 11:45 AM
Jeeperjunior's Avatar
I've been running full blown for a while. I think either Bush or Full would work fine.
Old Nov 5, 2008 | 11:49 AM
Erik@MIL.SPEC's Avatar
How much of a pain in the neck would running an inline pump be? I was thinking about the Bosch pump. Any insights?
Old Dec 6, 2008 | 04:08 PM
magyar86's Avatar
mellon was running a inline kenne bell pump and he was in the 90's on idc on 1000's then switched to the br dubble pump and droped in the 70's i believe..
Ckeesee12
Sep 9, 2016 07:46 AM
ryukinevo
Nov 13, 2015 12:00 AM
YFZracer32
Oct 19, 2015 12:03 PM
NewEvolutionIX
Jul 7, 2015 11:56 AM
EvolutionX9817
Jun 6, 2015 06:18 AM
