e85 on Stock evo *8* turbo?? (not 9)
Old Sep 7, 2010 | 08:00 PM
EvOstyleZ's Avatar
Ive been searching for awhile now and I cant find any info on owners running e85 on there stock evo "8" turbo...I see pages of evo 9 turbos on e85 but thats all..
Are there any dyno sheets or people with the stock evo 8 on e85 that can give there feedback on how its going so far, how much more power did u get? I know for a fact that the evo 9 turbo is a smart upgrade, but as of now im looking for stock evo 8 turbos on e85....what are you seeing in whp, track times ect.
Old Sep 7, 2010 | 08:08 PM
vanilla2's Avatar
I would save the money spent upgrading the injectors, fuel filter and all other mods needed to run e85 and spend it on a turbo. Then go e85, but I am curious to see evo 8 e85 results.
Old Sep 7, 2010 | 08:23 PM
ct9asilver's Avatar
https://www.evolutionm.net/forums/ev...no-5500-a.html
Here is one example, there all all kinds of posts with VIII turbo's on meth, some with the 9.8 housing others with the 10.5, this post happens to be on the 9.8
EvOstyleZ's Avatar
Yes this will be my futre setup for the remainder of this year...im not expecting any crazy high numbers just want to see what others have put down..
Next summer, is new turbo time...I would already have everthing ready for a bigger turbo...its just a matter of getting bigger injectors and a double pumper if needed.
Old Sep 7, 2010 | 08:29 PM
EvOstyleZ's Avatar
Thank you ct9silver, am I reading that correctly he put down 400 whp?
Old Sep 7, 2010 | 08:39 PM
donour's Avatar
Searched where? There's several in the dyno forum
d
Old Sep 7, 2010 | 08:40 PM
ct9asilver's Avatar
Thats what it looks like, but it seems a little high for a 9.8 VIII turbo. Maybe on a dynojet but on a mustang dyno probably more like 360-380. You can still run 11's though with 400 AWHP on a Dynojet
Old Sep 7, 2010 | 08:50 PM
EvOstyleZ's Avatar
d
Donour I like how you said theres several on the dyno forum, yet you posted the same exact link to a thread that ct9silver just posted
That seems like the only evo 8 turbo dyno sheet on e85 that i have found.
Old Sep 7, 2010 | 09:01 PM
donour's Avatar
It's at 5500', so there's like 20% altitude correction. Uncorrected is around 325 whp. The altitude kills, that's kind of the point of those charts. Notice how boost tapers off to 16 psi. That's not a mistake. That's all a stock turbo will hold up here, at 7500 RPM. Expect maybe 40 whp at sea level as well as 400 RPM faster spool.
d
EDIT: notice that it is _my_ dyno plot.
EDIT2: https://www.evolutionm.net/forums/ev...5-psi-e85.html
EDIT3:https://www.evolutionm.net/forums/ev...rbo-hp-tq.html
EDIT4: https://www.evolutionm.net/forums/ev...t-ons-e85.html
EDIT5: https://www.evolutionm.net/forums/ev...-er-tuned.html
EDIT6: https://www.evolutionm.net/forums/ev...3-evo-8-a.html
EDIT7: Anyway, I think you get the point...cheers!
Old Sep 7, 2010 | 09:14 PM
EvOstyleZ's Avatar
d
Thank you sir!
Would like to see some tack times too
Old Sep 8, 2010 | 04:23 AM
cheb evo's Avatar
Just tuned my car on e85 last Thursday. You can see the major differences in my signature with just a TBE, MBC, and Buschur open air filter without hardpipe. IMO, it is definitely worth the cost of injectors to gain 70 lb/ft of wtq and 60 whp. Plus, the added benefit of earlier spool up, as well as what feels like much cleaner pulls at WOT.
Old Sep 8, 2010 | 06:17 AM
blackmamba23's Avatar
Why not upgrade to with bigger punch.
Old Sep 8, 2010 | 10:13 AM
l2r99gst's Avatar
I think I posted my VD graph in the stock turbo thread. I'm an 05 8 turbo, though. But I made 400/400. It was the middle of winter though, but it was a conservative tune.
Old Sep 11, 2010 | 02:50 PM
hawjdude's Avatar
345/355 VIII turbo 10.5 hotside, E85, dyno-dynamics
Old Sep 17, 2010 | 05:54 PM
mr.4g63t's Avatar
I'm in the process of building my evo 8 with a 9.8 hotside 8 turbo on e-85. I have a tbe, walbro, gm boost soleniod, an all the pipping and ets front mount. Within this month I am installing kelford 272's with springs n retainers, fic 1050 injectors, head studs, an evo power o2 dump. I'm gonna get tuned for e-85 by reese tuning. i know this is an old post but I'll post numbers once everything is done.
