For you guys using the E85 testers...
Old Apr 28, 2011 | 07:50 PM
TurboTravis's Avatar
It can take quite awhile for the mixture to settle (over an hour) and get an accurate reading. I've got a feeling that some of us think we have higher E contents than we really do..
Old Apr 28, 2011 | 08:08 PM
05VIII's Avatar
Mine shows up in about 5-10 min and it will be the same an hour later??
Old Apr 28, 2011 | 09:08 PM
1outlaw's Avatar
If it takes longer than 5-10 minutes switch to distilled water at near the same temp as the fuel to be tested and most important- turn the sample over a couple of times and only lightly shake it- DO NOT SHAKE HARD- especially on 100 ml samples- you can emulsify it so much it can take a day to become accurate and then you can lose gasoline due to evap and still be off.
Old Apr 28, 2011 | 09:56 PM
05VIII's Avatar
+1. learned that after the first few trys. if its shaken hard, then it will take A WHILE. also noticed if its shaken to hard it builds a layer of foam between the alcohol and water. a few light shakes gets it just right.
Old Apr 29, 2011 | 03:34 AM
Benja's Avatar
I just tip mine upside down a few times and let it settle.
Old Jul 24, 2011 | 01:35 PM
Angel Evo's Avatar
where i can buy this ?
Old Jul 24, 2011 | 03:30 PM
10isace's Avatar
I bought mine on eBay for @ $8. You can try marine stores. I think they use ethanol for boats.
Old Jul 24, 2011 | 03:34 PM
Svendiesel's Avatar
Just google E85 testers lol
XTR Performance
Northeast Region
14
Jun 17, 2013 11:19 AM
E-Spec@Tach Motor Works
South Region
13
May 19, 2011 08:38 AM
EvOstyleZ
E85 / Ethanol
Apr 19, 2011 11:25 PM
R33E8
Jan 23, 2011 12:47 AM
mx5tc
E85 / Ethanol
May 9, 2009 12:39 PM
