US Govt possibly restarting an ethanol agenda
Old Jan 25, 2015 | 09:17 PM
  #76
nesraguy's Avatar
E85
I have read all the comments on this thread. Mostly very good. I would like to run E85 as it is 105 octane. In the early years of gas engines the best thing to control knock was ethanol. Deemed to be too expensive at the time. So lead was used to stop knock. Very bad indeed! Now we have ethanol fuels. Not the cure all for our engines but a nice alternative to premium gasoline. My only problem is that the closest station with E85 is over 20 miles from where I live. The next closest is just over 50 miles from me. I would have to spend a fair amount of money to make my car a Flex fuel vehicle. So until E85 is a little more available I cannot justify the expense to do it at this time. Don't get me wrong, I will use E85 someday soon.
Old Jan 27, 2015 | 08:39 PM
  #77
steven121's Avatar
Its an awesome fuel and yes hard to come by unless you have dual map tune, but I only wanted the evo to run on e85 only just have to plan my routes sometimes but it always works out
Old Jan 31, 2015 | 06:43 PM
  #78
Grimgrak's Avatar
Do flexfuel the right way, by keeping the gas aspect of it and using the ethanol set of injectors on a second pump/tank system that only comes on with higher boost.
Old Mar 18, 2015 | 02:57 PM
  #79
M4Lki3r's Avatar
Veteran: Marine Corps
Doing it right means:
Replacing the stock injectors with properly sized ones for E85
Installing an ethanol sensor
Getting an ECU that handles "FlexFuel" (EMS V2 for example)
Tuning for 91/93 and E85 and letting the computer do the fuel extrapolation based on ethanol content
Might also consider going speed density at this point as well.
Old Mar 18, 2015 | 03:59 PM
  #80
Grimgrak's Avatar
While your at it, move to a town with more e85 availability or did you not even read the OP's question.
Old Mar 19, 2015 | 08:48 AM
  #81
M4Lki3r's Avatar
You mean the OP from 2013 or 2015?
Either way, it is still cheaper to run it the way I posted with only one fuel system (4 injectors, 1 pump, 1 tank, 1 ecu) instead of 2 separate fuel systems (8 injectors, 2 pumps, 2 tanks, 1 ecu, etc)
Acree
Jun 23, 2011 02:08 PM
AWD Motorsports
AWD Motorsports - Florida
Jun 2, 2011 06:06 AM
TTP Engineering
EvoX 'For Sale' Electronics / Lighting / Audio
21
Dec 1, 2009 12:03 PM
Kc2Buk
61
May 5, 2006 11:39 AM
EVO316
South Region
34
Apr 20, 2006 01:07 AM
