Reputable tuner highly advises NOT to tune Evo VIII with e85
Old Jul 4, 2017 | 11:24 PM
  #61
Erik@MIL.SPEC's Avatar
Originally Posted by kaj
Vishnu. There's a name I haven't heard in a while...
My favorite was when the XEDE became a $700 paperweight.
I let that guy tune my car once. Once...
Old Jul 5, 2017 | 12:25 AM
  #62
2006EvoIXer's Avatar
I remember the XEDE came out after my ECUtek tuning at TT. So I don't have that paperweight.
And what happened to your tuning by Shiv?
Old Jul 5, 2017 | 02:48 AM
  #63
DRAGHICI's Avatar
Ivey gave me the same responce without even checking my compression, is my it Ivey?
Old Jul 5, 2017 | 03:32 PM
  #64
butte's Avatar
Originally Posted by 2006EvoIXer
My evo 9 makes 120 psi to all 4. Is my 56k mile engine dead too?
Sorry maybe I'm missing some irony in your post? Your numbers are healthy, the spec for a 9 is 90-145 psi
Old Jul 5, 2017 | 04:35 PM
  #65
Nice job w/the no.s. I had to look them up. Thats quite a range of variability
Old Jul 5, 2017 | 05:05 PM
  #66
RazorLab's Avatar
Most 9's would need rebuilds by now if anybody actually ever listened to WrongSaidFreds drooling replies.
His posts literally go against 15 years of knowledge of evos in the states.
Old Jul 5, 2017 | 05:27 PM
  #67
kaj's Avatar
kaj
We all know doing the test with the gas pedal down is wrong, though. His problem is probably just his fuel pump.
Old Jul 5, 2017 | 06:19 PM
  #68
I was just saying I doubt it is as bad as it looks. 125 is bad, but I think the HKS 274/278 cams made it look worse that it really is. It is a good sign that all compression are about the same. (I'm hopeful that his engine didn't pop on the dyno, but we won't know until we get an update)
I didn't know the IX compression was good to 90 psi (thanks for that), but mine is probably reduced because Vishnu likely adjusted my MIVEC map. I was seeing 140psi from other IXs when I was doing my compression test. I love all the info and knowledge on this site!
Old Jul 5, 2017 | 07:41 PM
  #69
RazorLab's Avatar
I
Just because it states 90 is lower limit doesn't mean it's good. Yea it will still drive...
Old Jul 5, 2017 | 07:52 PM
  #70
RazorLab's Avatar
Just so people get actual service manual numbers and not some shade tree scribblings at some point in this thread:
Evo 8:
Standard: 163psi
Minimum: 138psi
Evo 9:
Standard: 145psi
Minimum: 92psi
Evo 10:
Standard: 158psi
Minimum: 109psi
Limit between cyl: approx 14psi
Warm engine. Also, factor in your altitude!
triple L
Dec 30, 2012 10:03 AM
gatsu
Canadian Forum
19
Jan 27, 2011 09:55 PM
BlckEvo8
Oct 9, 2007 08:11 PM
phoenixM
Dec 23, 2002 05:43 PM
aerialcombat
Oct 16, 2002 01:53 AM
