Which Wideband For EcuFlash?
Old May 19, 2006 | 05:32 PM
  #31
TTP Engineering's Avatar
Lots of companies stating "we are going to do this, we are going to do that"... Zeitronix has been logging AFR+Boost+EGT+RPM+TPS+Lambda for years.
Get with the originator... Go Zeitronix.
Old May 19, 2006 | 07:21 PM
  #32
nj1266's Avatar
Originally Posted by chmodlf
I need to get a wideband O2 before I start tuning. Which one do you guys like?
I am leaning toward the Innovate or Zeitronics. There is also one by NGK that is a little cheaper (does not log).
What I am wondering is do I need to get one that logs or will the upgoming datalogging software suffice? Where would the wideband connect so that that data can be used in the log analysis (I'm referring to using a datalogger on the PC vs. in the wideband setup).
I do want a readout though (gauge or LCD).
I have the innovate LM-1 w/o the gauge. You can get the LM-1 with the Aux. box. or with the RPM converter. The latter is cheaper. You can log 5 different parameters with converter. Currently, I am logging the RPM, AFR, and Boost. I plan on adding an EGT sensor and log Throttle position and knock.
The nice thing about the LM-1 is that you can log WITHOUT a computer. You need a lap top with the Zeitronics to log. So if you do not have a lap top, you cannot use the logging feature.
The LM-1 box has a record button and I have it on a stand on a suction cup in the car. I simply press record when I want to log. Logging with the lap top is a PITA, unless you get a very small one.
Old May 19, 2006 | 07:56 PM
  #33
AlwaysinBoost's Avatar
I was really excited to see that ECUFlash would be intergrating the LC-1 into their software. I have an LM-1 w/RPM converter & XD-16 gauge in my other car. I have nothing bad to say about the innovative setup what so ever, works awesome. Their logworks software is great and super easy to use and setup. It can be a very powerful tool for tuning.
I'm looking forward to receiving my new LC-1 w/XD-16 gauge in the mail. But I'm really looking forward to using the logging capability of the ECUFlash software. Keep up the great work.
Old May 19, 2006 | 08:50 PM
  #34
nj1266's Avatar
Originally Posted by TTP Engineering
Zeitronix is the best value and feature packed unit, hands down...
But the logging feature is useless if you do not have a lap top.
Old May 19, 2006 | 09:04 PM
  #35
speed kills's Avatar
So is EcuFlash, if you don't have a laptop.
Old May 19, 2006 | 09:12 PM
  #36
BADEVO's Avatar
LOL , I was thinking the exact same thing.
Old May 19, 2006 | 09:41 PM
  #37
Damnit, you guys are teh smarter, teh faster...
Its no wonder you both run zeitronix.
Old May 19, 2006 | 09:42 PM
  #38
BADEVO's Avatar
chk ur damn pm's. LOL
Old May 19, 2006 | 10:10 PM
  #39
vboy425's Avatar
Zeitronix gets my vote. have it for 2 years. still loving it.
Old May 19, 2006 | 10:13 PM
  #40
nj1266's Avatar
I have no clue about the ECUflash. I was simply commenting on the Zeitronix vs. Innovate. I keep my innovate LM-1 in the car and ready to log at the press of a button. The power cord comes for the cig lighter. You cannot do the same thing with the Zeitronix. It is not practical to have a lap top attached to the Zeitronix and ready to log all the time. The LM-1 is much easier to log with.
Old May 19, 2006 | 10:15 PM
  #41
nj1266's Avatar
Do you log with the Zeitronix on a daily basis?
Old May 19, 2006 | 10:18 PM
  #42
BADEVO's Avatar
Thats great, but the topic of the thread is using a wideband with ECU Flash. So if your logging with ECUFLASH it should be understood a lap top is being used. Just my 2 cents
Old May 19, 2006 | 11:27 PM
  #43
nj1266's Avatar
All this is a moot point. ECUflash already said in this thread that they are integrating Innovate products in their software. So getting an LM-1/LC-1 is a no brainer. Or you can get the Zeitronix and try to integrate it with the ECUflash on your own. Good luck.
Old May 20, 2006 | 01:49 AM
  #44
Evo_Jay's Avatar
I have Zeitronix and i love it.
I bought the ZT2 kit for 280
MAP sensor for 110
Vishnu Knock buffer for 110
(hooked up the knock buffer to the user input)
And for 500$, I can log
Lamba
A/F ratio
TPS
RPM
Boost
and....
Real knock.
All at 74 sample per peramiter per. sec
No other system can give you that much loggin power for the price.
Old May 20, 2006 | 01:52 AM
  #45
Evo_Jay's Avatar
You can NOT log knock with any Innovate product. Hooking up the stock knock sensor just to a 0-5v input wont log anything and probably will load down you knock sensor, which is dangerous.
