Which Wideband For EcuFlash?
Old May 20, 2006 | 03:57 PM
  #61
Evo_Jay's Avatar
Originally Posted by nj1266
When I said you need a lap top, I meant that it is TOO cumbersome to carry a lap top with you ALL the time in order to log. Believe me I tried logging with a lap top with my Xede and driving at the same time. It is a PITA. With the Innovate the LM-1 unit is right there attached to a suction cup on the windshield. Press the red record button and you are logging. Press it again and you are done.
I do TWO 3rd gear logs per day. One on the on ramp to the freeway on my way to work and one on the on ramp from work. Imagine what a PITA that would be if I had to carry a lap top with me EVERY DAY.
Do you have your lap top in the car every day? Would you leave your lap top in the car like I leave my LM-1 every day?
All I am saying that it is a hassle to log with the Zeitronix. That is all.
You must have a sh!tty tune if you have to log it everyday and make sure your engine isn't gonna go.
Old May 20, 2006 | 04:13 PM
  #62
l2r99gst's Avatar
Originally Posted by Evo_Kid
A knock sensor (aftermarket or stock) is just a microphone.
Yes logging just the knock sensor voltage does nothing.
Thats why you need a knock buffer or some type of circuit to process the voltage.
Yes, you were talking about is knock correction and timing. DO you even know how a knock sensor works???
It's just a microphone, it listens to the motor. When there is knock or det., there is a spike in the noise. This is knock.
The stuff your talking about is what the ECU does when it sees that spike. The ECU can see the spike because it doesn't just read voltage. It processes the voltage (just like the knock buffer and ECU+), so it can see these spikes. Then it changes timing using knock correction.
If you dont understand, go read a book.
Are you in high school or something? Why don't you try to learn stuff from other people when they post.
I have an Engineering degree and have had experience tuning and logging from stock ECUs for years. I think you may need to read a book, especially on the working of a stock ECU and knock retard. Because obviously you have no clue what I am referring to.
I'm done wasting my time answering your posts.
Old May 20, 2006 | 04:20 PM
  #63
racegate's Avatar
Logging knock voltage spike outside of background is a very rudamentary way of monitoring the signal. In reality, the stock ECUs (which have some of the most sophisticated knock detection mechanisms in existance) perform a lot of conditioning on the signal, run them through an FF Transform, and other algorithms to detect knock. Looking at amplitude is just one piece of the puzzle, and works marginally, at best. There's more to a signal than amplitude variances (what is commonly referred to as a 'spike' in the voltage).
Old May 20, 2006 | 04:23 PM
  #64
l2r99gst's Avatar
Thank you. I was tired of trying to talk to him.
Old May 20, 2006 | 04:41 PM
  #65
Evo_Jay's Avatar
OK, thats why Al logs knock using his Innovate stuff and the voltage.
Also, Shiv logs knock using his knock buffer and an XEDE.
If the two top tuners can log knock doing it that way, then so can I.
Also, I didnt say the signal is just amplified, its processed (conditioned and such just like the stock ECU does). I know just amplifiying the signal is only one piece of the puzzle.
ALso, I know what knock retard is.
And to GST, Im a lot older then you think, a S/N means nothing.
Old May 20, 2006 | 04:44 PM
  #66
TTP Engineering's Avatar
If you do not have either unit and you have an ECUFlash and you know that ECUFlash is going to integrate Innovate into their software, which one will you get?
Zeitronix, there are a stack of broken and malfunctioned Innovate LM1's at the local dyno.
The same dyno shop IS AN INNOVATE DEALER and advises not to waste your money on them as they are not taking back these defective crap units.
Old May 20, 2006 | 04:48 PM
  #67
Vijay is correct. I log knock sensor NOISE by tapping a trace on a LinkElectrosystems Knocklink. On a most recent pass The knocklink was in the red most of the run indicating "knock" as displayed.
According to the Palmlogger there was ZERO timing hold or retard based on comparison to the ignition timing load cells I programmed...
Logged "knock", ECU saw no knock.
Old May 20, 2006 | 05:58 PM
  #68
nj1266's Avatar
No I do not have a ****ty tune. My AFR is at 10.9-11.2 across the board. And my car boosts to 21-22 psi depending on weather conditions. I like to learn and experiment a lot. That is why I got an AFR unit that makes it easy to log. And despite the two logs that I do per day my car still get 22 mpg. Please do not jump to conclusions about the state of my car's tune.
Old May 20, 2006 | 06:02 PM
  #69
nj1266's Avatar
Sorry dude, but you sell the Zeitronix and you have a vested interest in selling them and that is why you hype them. Both innovate and Zeitronix are great units. I am not saying that the Zeitronix is a bad unit. It is a great unit. But if you want to log daily, then it is a PITA to have a lap top in the car.
If Zeitronix solves this problem by allowing their device to log, then I will sell my innovate and get won.
Old May 20, 2006 | 08:14 PM
  #70
speed kills's Avatar
he use's ZT-2 every day in his car, and he does not go out telling people to buy it too. You can see in his sig what he has done for the Evolution community. Everyone has a choice of what to use: Zt-2 or innovate. We can only put our feedback on it. We all are on the same side to get things better for each other, not to prove who is better.
Old May 20, 2006 | 10:33 PM
  #71
ScrappyJack's Avatar
Lightbulb
I think he's told people to buy it about 5 times in this thread alone.
Zeitronix, Innovate, FJO, PLX, TechEdge, et al... they all have their pros and cons. There are plenty of threads about widebands on this site and even more information is available elsewhere. There is really nothing that is application-specific to the ECU Flash that would determine which wideband to get - until we see what the integration with the Innovate product line will entail.
Old May 21, 2006 | 06:41 AM
  #72
MalibuJack's Avatar
Not to mention coding is modular, so adding functionality for widebands in the logging software that may or may not ever materialize is likley just a factor of adding either a simple addon, or a definition for it..
It will be interesting as more is known about the firmware in the stock ECU, there are several 5v inputs that are currently unused... Opens the door to some interesting possibilities once the roms are completely reverse engineered and the code itself is able to be modified.
Old May 21, 2006 | 08:25 AM
  #73
[QUOTE=ScrappyJack]I think he's told people to buy it about 5 times in this thread alone.
In this thread alone you say, How come i missed it all five times. Now people should do what they are told, right
Old May 21, 2006 | 02:07 PM
  #74
Why do you have two screen names?
ScrappyJack and Jack@Evostore?
That is against evolutionm.net policy and borderline "shady" since YOU are an Innovate, PLX and FJO dealer for Titan/Evostore. Why you post under two screen names is beyond me.
Old May 21, 2006 | 02:16 PM
  #75
I bought a Zeitronix at RETAIL PRICE, I am not sponsored, nor ever was, never recieved anything for free from them, unlike warrtalon for example.
I contacted them because I was so impressed with the product that I just had to become one of 3 authorized dealers in the U.S.
If I saw a better product out there for the money, that is what I would recommend because that is how we do things.
_________________________________________________
The point is that a laptop is needed to reflash ECUflash.
The same laptop will be used to datalog.
When the car is tuned, you do not need the laptop for the ECUflash any longer, right?
When the car is tuned, you do not need the laptop for zeitronix logging either because your tune does not change on its own.
Zeitronix has live display of EGT, AFR, Boost on the LCD with peak hold boost and EGT buttons. There is no need to datalog, unless you are tuned on the edge of maximum performance and want to be able to make some additional logs while racing.
