Starting to tune.. logs and such inside
Old Jul 25, 2006 | 07:00 AM
  #136
MalibuJack's Avatar
I plan on using washer fluid (50/50 mix) exclusively so you know my answer.. you can run better gas and your 50/50 mix.. typically you can run even more timing.. I don't think running any leaner will get you much more power though, just end up removing a margin of safety you get if the alky kit shuts off.
Old Jul 25, 2006 | 07:28 AM
  #137
justchil's Avatar
Will the "dye" in washer fluid not cause a problem? Or do you plan to use a clear washer fluid?
I will give either 100 or 112 + 50/50 a try either this week or next week
Old Jul 25, 2006 | 07:26 PM
  #138
justchil's Avatar
Holy **** batman. After comparing to a few other timing tables and the timing from the stock rom I've done some adjusting at lower loads (100-180 mainly). For some reason or another my values were WAY lower than stock.
I think I may have taken a lot of lower load values down up to 5 digits when I first started learning.. and never put them back Anyhow my tq is back and the car breaks loose a lot easier
This stuff is getting so involved I can't really find time to sit down and post up something usefull.. so I'll continue to babble on this thread
Old Jul 30, 2006 | 04:22 AM
  #139
justchil's Avatar
BTW 50/50 alky/water + 100/93 mix = much fun. As soon as I can get some decent weather at the track we'll see how fun. The car is definately making damn good power. The sunroof cover slides open when I go WOT now (really wish I didnt have the sunroof)
Old Jul 30, 2006 | 05:26 AM
  #140
MalibuJack's Avatar
I have this stuff thats yellow in color.. I doubt the dye makes any difference or hurts anything.. Washer fluid typically is just water/methanol/detergent/dye and the detergents in it are no different than the type of stuff in gasoline already. Its just more widely available...
I don't use pure methanol because up to 30% of it can evaporate in a few hot days, I don't use pure water because it will freeze on a cold day..
I do use washer fluid because you can usually get it when you fill up your car at a gas station, so its convenience..
Tuning for it is the same as tuning a 50/50 mix water/meth...
It also keeps me from overdoing things with my tune since the meth controllers or pumps from everyone I have seen, have a pretty high failure rate,
I have even experimented with model airplane fuel which is methanol/castor oil/10-20% nitromethane.. Don't do it.. I ran my best times with it, but went severely lean when it kicked in, you need to run your tunes intentionally richer to compensate for it..
