Starting to tune.. logs and such inside
Old Jun 29, 2006 | 04:11 AM
  #76
AutoXer's Avatar
Originally Posted by justchil
That could be it. I know it goes to 21 AFR which is the leanest my wideband reads.
My OBDII logger has always shown zero for O2 voltage when the throttle plate is closed at an above idle RPM. I believe the ECU shuts off fuel when:
RPM > some value above idle
TPS < some very low value
I'm not sure what the values are.
Old Jun 30, 2006 | 07:09 AM
  #77
justchil's Avatar
Guys I ran the car last night at the local 1/8 mile track.
Before I was running 7.7's at 90mph...
I ran a 7.55@92.3mph yesterday
Old Jun 30, 2006 | 07:48 AM
  #78
C6C6CH3vo's Avatar
Removing the honeycomb tonight!
JK
Old Jun 30, 2006 | 09:56 AM
  #79
Noogles's Avatar
Congrats!
Next time i want to see you out there on 30 psi and a more aggressive map
Old Jun 30, 2006 | 10:11 AM
  #80
justchil's Avatar
How about 27psi but more aggressive map.
Only thing is I think I may have done a little damage the the TC... I noticed today during decel 1st gear it's a whining a lot louder than normal. I change the fluids every other oil change and it's due for one so we'll see. Almost 55k miles on a complete stock drivetrain (other than clutch).
Old Jul 5, 2006 | 01:50 PM
  #81
justchil's Avatar
Ugh. Putting a maf in with a honeycomb has been a big pain in the ***. I've added .1-2 of fuel here and there and the car is still running too lean. I'm going to clean the maf with alky and if that doesnt work I'll put my old maf (no honeycomb) back in. It's possible that the damaged o-rings on the injectors are to blame as well.
Hopefully the weather clears up some so I can get back to it!
Old Jul 6, 2006 | 02:10 PM
  #82
justchil's Avatar
Ok well I've got rid of most of the knock.. but the car feels like *** now lol
Noogles if you've got a little time would you mind taking a look at my map/logs again?
I'm almost thinking I may have got a ****ty tank of gas. I've got to get this tune sorted out soon.. 14th is dyno day
Old Jul 6, 2006 | 02:12 PM
  #83
TTP Engineering's Avatar
Oh no... Here we go again... You are starting to sound like... err, nevermind...
Old Jul 6, 2006 | 02:20 PM
  #84
sonicnofadz's Avatar
Maybe you should just pay Al $50.00 for a base flash, and take it from there?
Old Jul 7, 2006 | 10:17 AM
  #85
thatsMR2u's Avatar
did u do all the tune yourself? just cause i noticed alot of things are changed on your map which arent usually changed on say stock or dynoflashed cars such as... accel enrichment, injector battery voltage latency compensation, and idle stepper look-up table that i couldnt figure out- im gonna try changing a bunch of those in my map to resemble yours and see how it works out
Originally Posted by HiVoltEVO8
This map is fron a 2003 that has the following mods
GSC cams 272 set at -2/-2
Precision 680 cc/injectors
no cat
TBE
10.5 hotside
Ebay Turbo outlet
AMS FMIC
stock air filter/box
93 octane
MBC Forge
entire map is scaled to 325 load. However, it has only been tested to 21.5 psig (<280 load)
Note: Immobilizer code is set at "0000" .......you will need to change it to your code
Use at your own risk....but it should be close enough to eliminate most of your problems.
Anyone can feel free to comment on it
HiVolt
Old Jul 7, 2006 | 10:26 AM
  #86
chmodlf's Avatar
You forgot boost leak
  #87
justchil's Avatar
I want my injectors scaled. I've paid Al almost 1000 dollars for tunes already :P
I started with a custom dynoflash tune but have totally redone the fuel/timing tables. I didnt change: accel enrichment, injector battery voltage latency compensation so I would assume thats from my dynoflash. Actually that might be part of my problem I'm having right now with lean spoolup.
The idle stepper table is back to stock... minor changes on the ISVC or ISCV settings
Old Jul 7, 2006 | 10:31 AM
  #88
justchil's Avatar
LOL TTP! I dunno about you guys but I test for boost leaks every oil change. :x
I didn't even notice the couple things that thatsMR2u pointed out. Noogles has been helping me with this a lot so it's possibly he tweaked these settings.
I've got a bet going with Nick@BR that I will put down +13hp on pump gas in comparison with my last custom tune/dyno so we'll see.
Old Jul 7, 2006 | 11:59 AM
  #89
thatsMR2u's Avatar
nice, keep the safe power coming!!- and post up ur noogles pimped map
Old Jul 7, 2006 | 12:03 PM
  #90
justchil's Avatar
I will once it's completed
