Starting to tune.. logs and such inside
Old Jun 28, 2006 | 05:49 AM
  #61
justchil's Avatar
I am still getting the P0171
Another thing too: The oxygen sensor reading on evoscan seems to go to 0 here and there. Either this is a bug in the software on it's possible I have an o2 sensor on the fritz.
Old Jun 28, 2006 | 07:24 AM
  #62
AlwaysinBoost's Avatar
Originally Posted by justchil
Did you notice that my peak air flow hz was exactly 1603.95 serveral times? Same in other logs. I'll get a better evoscan log soon.. It kept crapping out on me as I was driving around today but i think I've got it fixed.
Car pulls smooth and hard.. way better than before. I'm going to try to dyno again @ BR July 7th. Hopefully I can get two hours of time so I can swap gas/maps and get some good data on my car
One thing on the timing. Do you think tapering the idle advance might help idle out some?
My "base" flash increases with load.
the example:
Are you getting any timing being pulled in the mid to upper RPM range with that map? How much boost are you running and what kind of fuel do you use.
From the maps that I've seen those seem like pretty aggresive timing curves on pump gas.
Old Jun 28, 2006 | 04:36 PM
  #63
sonicnofadz's Avatar
Ummmm...how are you trying to tune with a destroyed MAF sensor?
Roger that.
One thing I've thought off.. I currently don't have the honeycomb in my MAF. Mine was destroyed and the one I bought.. well the guy didnt bother to tell me it was missing.
Old Jun 28, 2006 | 05:45 PM
  #64
justchil's Avatar
I bought another one.. it's mint other than no honeycomb.
Old Jun 28, 2006 | 05:52 PM
  #65
Correct me if I'm wrong, but the MAF will not work properly unless there is a honey comb in place.
Old Jun 28, 2006 | 05:58 PM
  #66
HiVoltEVO8's Avatar
Wink Here is a map to start with
This map is fron a 2003 that has the following mods
GSC cams 272 set at -2/-2
Precision 680 cc/injectors
no cat
TBE
10.5 hotside
Ebay Turbo outlet
AMS FMIC
stock air filter/box
93 octane
MBC Forge
entire map is scaled to 325 load. However, it has only been tested to 21.5 psig (<280 load)
Note: Immobilizer code is set at "0000" .......you will need to change it to your code
Use at your own risk....but it should be close enough to eliminate most of your problems.
Anyone can feel free to comment on it
HiVolt
File Type: zip
Old Jun 28, 2006 | 06:17 PM
  #67
I can't open your file, says its corrupt.
Old Jun 28, 2006 | 06:31 PM
  #68
andenbre's Avatar
does it go to 0 durring decel?
Old Jun 28, 2006 | 07:35 PM
  #69
HiVoltEVO8's Avatar
Question
try this one....I zipped it and extracted it and it was fine
HiVolt
try this link
http://www.savefile.com/files/3131744
Old Jun 28, 2006 | 07:39 PM
  #70
justchil's Avatar
That could be it. I know it goes to 21 AFR which is the leanest my wideband reads. I would like to get rid of the P0171 it's pretty annoying.
I'm going to get a new maf as soon as I can find one that's perfect I've been missing the honeycomb for some time now with no serious issues.
Old Jun 28, 2006 | 07:48 PM
  #71
that link worked.
what tools did you use to tune your car? Did you use the dyno or street?
Old Jun 28, 2006 | 07:49 PM
  #72
C6C6CH3vo's Avatar
Were you able to tune around the missing aluminum honeycomb? If so then who needs them is what I'm thinking
Old Jun 28, 2006 | 08:05 PM
  #73
HiVoltEVO8's Avatar
Talking
that link worked.
Street tuned
PLX wideband and ECU+
According to the ECU+ dyno 285 tq at 4300, 283 Hp @ 6700, 0% tranny loss, 3600 lb car
HiVolt
Note....ECU+ plus set at zero correction
Old Jun 28, 2006 | 08:14 PM
  #74
Noogles's Avatar
e-mail me your tune and log and i'll take a look at it.
Old Jun 28, 2006 | 08:44 PM
  #75
justchil's Avatar
The timing map above was before... I just now have logging software as I had faith in a custom dyno tune... car is much much smoother now!
22psi on pump 93
