Throttle hang and the Idle Stepper Table
Old Nov 11, 2007 | 10:31 AM
  #226
EvoBroMA's Avatar
sick, you should log icv steps before and after the update.
Old Nov 11, 2007 | 01:08 PM
  #227
Max Power's Avatar
Originally Posted by gunzo
Thats because the locations for the desired ISCV are wrong
That makes sense... so even if I change the axis on my ISCV lookup table, the "desired" tables will still have the wrong data. Am I guessing that nobody is really adjusting or looking at the "desired" tables and just changing the lookup table?
Old Nov 11, 2007 | 01:50 PM
  #228
MR Turco's Avatar
I dont think anyone wants to invest a ton of time into it. If we can get it to work/fix the throttle hang with little investment i think it will make everyone happy.
Old Nov 11, 2007 | 04:40 PM
  #229
Evo_Jay's Avatar
Here is my current setting. It has cold start and eliminated or nearly eliminated all the throttle hang.
That pic is horrible. anyways, its 58s all the way down the last row.
Old Nov 11, 2007 | 04:41 PM
  #230
Evo_Jay's Avatar
Originally Posted by MR Turco
How does this look? I changed the map to reflect load and coolant temp. I think the load values make sense right?
I am going to load it on this weekend and try it. I forgot my cable or i would have done it for the ride home from work.
I tried this one, didnt give enough cold start ie. went to idle too soon. Try out my settings i posted above and let me know how it works for you.
Old Nov 11, 2007 | 04:53 PM
  #231
MR Turco's Avatar
^^^ Yours looks good. I would even go to 51.
Old Nov 11, 2007 | 05:03 PM
  #232
inco9nito99's Avatar
65's were fine, 58's are better, 51 I didnt notice any difference.
Old Nov 11, 2007 | 05:05 PM
  #233
Evo_Jay's Avatar
I did 50, from the 51 row down and after cold start, the idle was too low. I also tried 0 from the 51 rowdown, but that didnt work.
I think we can taper it back down hitting 0 by the last row in the last colum, but thats just a though.
Old Nov 11, 2007 | 05:09 PM
  #234
Evo_Jay's Avatar
heres my example of taping it to 0. Im gonna try it out later.
sorry pic is sh!tty
Old Nov 19, 2007 | 05:09 PM
  #235
blackdemon's Avatar
I also have the same throttle hang problem this is my idle table. What should I change? [IMG][/IMG]
Old Nov 19, 2007 | 06:08 PM
  #236
Evo_Jay's Avatar
Make it look like the pic in my post, #229. With those setting you should have no throttle hang and still have cold start.
Old Nov 19, 2007 | 06:27 PM
  #237
blackdemon's Avatar
My tables looks completely different than yours. on top yours says temps while mine is throttle possition. And your rpm is lower. How do I go about changing mine?
Old Nov 19, 2007 | 06:45 PM
  #238
EvoBroMA's Avatar
https://www.evolutionm.net/forums/sh...&postcount=206
Old Nov 19, 2007 | 11:19 PM
  #239
al\lupo's Avatar
sorry pic is sh!tty
Did you tried that?
Old Nov 19, 2007 | 11:58 PM
  #240
Evo_Jay's Avatar
it doesnt matter. In my pic those are the correct things. post below yours shows the post that talk about the correct scaling.
Regardless you an still change teh table and it will work.
