ECUFlash / Evoscan / Mitsulogger Questions
Old May 3, 2009 | 11:24 PM
  #571
TwoFour's Avatar
This is the Error I get, "Object reference not set to an instance of an object" . How do I stop it from doing this?
Old May 5, 2009 | 11:52 PM
  #572
SMOKDU's Avatar
how do you change the flash to be able to flash to another car... Is it the Id number???
Old May 6, 2009 | 04:55 AM
  #573
MR Turco's Avatar
I have also been getting this very frequently when using the AEM uego. It only happens on some of the cars that i have tuned. It is very annoying becuase it totally stops the log. The uego still seems to work through Hyperterm and mitsulogger so i am not sure why EVOscan is having an issue. this is on evoscan 2.5
Old May 6, 2009 | 06:59 AM
  #574
TwoFour's Avatar
Rom ID and immobilizer
Old May 6, 2009 | 07:03 AM
  #575
TwoFour's Avatar
I got it to work , I restart the computer, turn off car, plug in USB's, computer turns on, turn car on, start evoscan. Then log , works now.
Old May 6, 2009 | 08:58 AM
  #576
MR Turco's Avatar
yeah mine didn't work even after reboot. I am using straight serial no USB adapter.
Old May 6, 2009 | 12:36 PM
  #577
TwoFour's Avatar
Yeah that's all I did. Did you make sure you have the right com port selected in your Device Manager?
Old May 6, 2009 | 07:21 PM
  #578
Wiznaz's Avatar
I'm currently using version 1.35 of Ecuflash. I have a bunch of the additional patches besides Tephra's 5.1 such as lean spool disable, O2 sensor bypass, P0300 etc. I was wondering if I have to start with a fresh map and re-apply all the patches in a new rom again in order for 1.4 to recognize everything correctly also because I see there are multiple Evo9base files now. My apologies if this was already covered.
Old May 7, 2009 | 10:45 AM
  #579
TwoFour's Avatar
You should copy over your modded files.
Old May 9, 2009 | 02:15 AM
  #580
fatal1ty's Avatar
Hi,
I am unable to register as new user on openecu.org forum (http://forums.openecu.org/). For weeks I have been getting this message after clicking on submit:
[phpBB Debug] PHP Notice: in file /includes/functions_user.php on line 3383: domdocument() expects at least 1 parameter, 0 given
Fatal error: Call to undefined function: load() in /home/tactrixc/public_html/openecu/forum_v3/includes/functions_user.php on line 3384
Is the registration down or the user number is full?
Old May 9, 2009 | 04:45 PM
  #581
raasfaas's Avatar
I just recently upgraded to the latest ecuflash version 1.41 and now I'm not able to view my logs in evoscan using the maptracer. Whenever I got to upload the xml/hex file it says that the xml file is not compatible. Anyone else having trouble viewing the maptracer using v1.41 and evoscan v2.5?
Old May 10, 2009 | 12:11 PM
  #582
TwoFour's Avatar
have the same problem ^^^
Old May 13, 2009 | 09:24 PM
  #583
evo_q8's Avatar
Want to know if the ECUFlash definitions for the EDM 08+ Evo's and Sti's are out yet?
I just tried getting the roms and did save them, but seems to be of no use. Any updates. Do let me know. I can mail the roms to you guru's out there!
Thanks!
Old May 15, 2009 | 02:55 PM
  #584
evo_q8's Avatar
help please!!
Old May 16, 2009 | 01:54 PM
  #585
fugiwara's Avatar
I am having problem w/ evo scan and mitsulogger, none of them work w/ my Vista 64 bit please help
