ECUFlash / Evoscan / Mitsulogger Questions
Old Nov 2, 2010 | 05:55 AM
  #856
Mitsu.kid.02's Avatar
Originally Posted by tscompusa
what operating system? im curious maybe you didnt fully uninstall it when you tried to. evoscan embeds itself to:C:\Users\YOURCOMPUTERNAME\AppData\Local\Virtual Store\Program Files (x86)\EvoScan
with windows 7, so in order to remove it 100% you must remove it from that directory as well as registry entries.
Sounds like to me its something to do with permissions. maybe its trying to write to a directory its not allowed to on your windows user? change the saved position to the log file to your desktop and see if that relieves the issue.
its weird i have evoscan saved in two locations it seems. Im using windows XP pro BTW. The first directory is "C:\Program Files\EvoScan\EvoScan v2.7" The other one is "C:\Documents and Settings\Administrator\My Documents\EvoScan v2.7" Is this what you mean?
Old Nov 10, 2010 | 12:47 PM
  #857
boosted91t's Avatar
I am having trouble logging 2 byte. Evo 9, 88590015 tephra v5, the mut tables are correct. I changed the equation in evoscan for 2 byte load and rpm from .3125* to 1000* My rpm will log correctly, but having an issue with the load. It will read in the mid 300's at idle. I changed the equation over 2 decimal points to 10.00* then my load wot was 360. I shouldn't be anywhere near 360 load wot.
Thanks in advance
Old Nov 10, 2010 | 01:06 PM
  #858
raasfaas's Avatar
Any specific reason your logging 2 byte load instead of 1 byte load that comes with the Tephra mod?
Also, you shouldn't have to be changing any equations in evoscan to log 2 byte, all you have to do is make sure the MUT table address match the request ID's in the data.xml file for evoscan.
IIRC 2 byte load for that ROM is 6B42 & 6B43.
Old Nov 11, 2010 | 06:22 AM
  #859
boosted91t's Avatar
I think I was confusing myself with the 1 byte and 2 byte. I read the thread but its hard to understand with my limited ecuflash knowledge. I just realized I could change my 1 byte to 1.3 in ecuflash, so as long as my evoscan equation is 1.3 it will log the actual load the car is hitting?
Old Nov 11, 2010 | 06:59 AM
  #860
Raptord's Avatar
That's correct.
Old Nov 11, 2010 | 07:52 AM
  #861
raasfaas's Avatar
It sounds like you didn't remember to copy over the info to your evoscan's data.xml to be able to log 1 byte load...because you shouldn't be getting 300% load at idle.
Did you add this:
<DataListItem DataLog="Y" Color="" Display="Load 1Byte" LogReference="Load1B" RequestID="41" Eval="1.2*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="270" ChartMin="0" ChartMax="270" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Nov 11, 2010 | 07:54 AM
  #862
raasfaas's Avatar
Also, V5.10 comes default as 1.2 load factor, which allows you to log up to 306% load (1.2*255=306) So a 1.3 factor would allow 331% load.
Old Nov 11, 2010 | 12:04 PM
  #863
jasons9594's Avatar
Ok im pretty new to tunning...Ive tunned my car on ecuflash with the stock turbo setup..I just upgraded to a bigger turbo setup and i have skimmed threw this thread looking for where i can change/mod my fuel/boost cut so i can run more boost but i havent been able to figure it out...I was told by another guy that i need to change my fuel cut table but i do not see that in my ecuflash any where all i see is decel tables? sorry if its a noob ? but i just dont know the answer so i would like some feedback please....
THANKS
JASON
Old Nov 11, 2010 | 01:21 PM
  #864
boosted91t's Avatar
Thanks Raasfaas I had the wrong equation in the xml, working good now!
Old Nov 11, 2010 | 04:00 PM
  #865
raasfaas's Avatar
THANKS
JASON
Its there in ecuflash, its under the heading "boost cut load"
Old Nov 11, 2010 | 04:01 PM
  #866
raasfaas's Avatar
Old Nov 12, 2010 | 11:33 AM
  #867
jasons9594's Avatar
I must need to update mine...i dont see it!
Old Nov 12, 2010 | 11:43 AM
  #868
jasons9594's Avatar
Ok i just found it under turbo boost single solenoid..
THANKS
JASON
  #869
raasfaas's Avatar
what version of ecuflash are you using?
Old Nov 12, 2010 | 11:46 AM
  #870
raasfaas's Avatar
The older versions have it under "Turbo" heading as boost limit.
