ECUFlash / Evoscan / Mitsulogger Questions
Old Jan 17, 2011 | 12:02 PM
  #916
KentStateTsi's Avatar
Veteran: Army
Should I hear the injectors click when I test them in the actuator section? Reason I ask is because I had my car started for like 10seconds after my build on 1650's and now I can't get anything. I switched back to 550's and still nothing. No DTC's, but I don't hear anything when I test the injectors. Another question I guess. Is there a different formula for q45 tps sensors?
Old Jan 17, 2011 | 08:09 PM
  #917
EVO8emUp's Avatar
IIRC, no. I think you use that feature when your car is running. I think it only disables the injector for a few seconds.
Old Jan 18, 2011 | 01:17 PM
  #918
milford's Avatar
i have a evoscan/tephra question maybe someone can help me with. Are the latest tephra roms pre configured with 2byte load? basically what i am trying to figure out is.. can i open my evoscan version 2.8 and simply click to choose the 2byte load option and successfully log load that way? i notice i can choose from a few load options..i am wondering what is the best to log with if i cant just choose the 2 byte option in evoscan without modifying my rom further? Thanks to anyone who can adivice me.
Old Jan 18, 2011 | 01:45 PM
  #919
Raptord's Avatar
If you're using tephra mod then log 1byte load. I think you have to manually add it to evoscan, but its the most accurate load you can log with tephra
Old Jan 18, 2011 | 02:00 PM
  #920
Mellon Racing's Avatar
personally I don't like 1byte, it may be more accurate but it causes gaps in the data and odd values that are impossible. 2byte ftw
Old Jan 18, 2011 | 09:22 PM
  #921
Raptord's Avatar
What kind of gaps? I've never had that happen to me.
Old Jan 22, 2011 | 04:16 AM
  #922
MrEclipse's Avatar
Is there anyone who can help me? I need a rom for my eclipse 2003 GS AT??
Old Jan 22, 2011 | 05:50 PM
  #923
milford's Avatar
can someone point me in the right direction ...I want to install an omni 4 bar so i can log boost. I know that there is xml i need to add into my rom and i know the thread that has that xml. my question is... since i am using a v7 rom what xml should i be using and is there a thread that has this information in it? any help getting this figured out would be much appreciated.
Old Jan 27, 2011 | 10:53 AM
  #924
milford's Avatar
bump
Old Jan 27, 2011 | 11:31 AM
  #925
Raptord's Avatar
You need to add the relevant XML data for the OMNI to the v7 xml.
Without trying to sound like an ****, you probably could have found everything you need to know in this thread after a brief search:
https://www.evolutionm.net/forums/ec...t-control.html
Old Jan 27, 2011 | 11:41 AM
  #926
milford's Avatar
didn't think to look in that thread because i am not looking to convert to ecu boost control. but thanks for you help. I know i need the relevant xml for my v7 rom. but the only xml i have found that seems relevant is the xml listed for a 03 evo rom. but i have a v7 rom so that is why i am trying to find out if the xml is different for that rom
Old Jan 27, 2011 | 11:48 AM
  #927
milford's Avatar
https://www.evolutionm.net/forums/ec...evo-8-9-a.html this thread has the xml listed for an 03 evo rom..but i am using v79653X706. wondering if the xml in this thread is what i need to add to my rom?
Old Jan 27, 2011 | 06:38 PM
  #928
dmotors's Avatar
wierd afr readings
i have the lc1 innovate wideband and on evoscan and access race tuner logs the afr without the first number , the numbre one is missing any help.
on the logworks program reads perfect
Old Mar 11, 2011 | 02:56 AM
  #929
YaroRS's Avatar
guys need advice, downloaded new version of evoscan 2.8 and it stopped reading DTC errors ! I connect it to the ECU (check is there, on the dashboard), but evoscan says no errors stored ! Any solutions what to do with this ?
Old Mar 15, 2011 | 06:15 AM
  #930
escodotcarter's Avatar
Can someone please tell me how to log 2byte load with Mitsulogger v1.6 Beta 3. my ROM ID is 88590015. I finally got my AEM wideband to log properly but now i cant log any load. Im desperate please some one PM me or call me 845-821-3399. I need step-by-step instructions since im verrrry new at this. Thanks for the help guys.
