log WGDC in EvoScan
Old Mar 29, 2007 | 08:13 PM
  #61
RedV's Avatar
Originally Posted by mrfred
I've been doing more WGDC logging, and it looks to me like the ECU does integrate over time or rpm, but there is no derivative which is causing late BCS response and load overshoot in 2nd gear. (Target load is 240.) However, I've got pretty good control over the load in 4th-6th gear where the rpms build more slowly. I'm trying to figure out how to fix this without having to slow the rate of spool-up. Anyone have any suggestions?
4th gear pull:
Can I ask a bit of a newb question here? What logging software/graphing tool are you using to log and get such nice graphs of your boost level? Can this be done with a JDM MAP sensor and EvoScan?
Thanks
Old Mar 30, 2007 | 06:33 AM
  #62
mrfred's Avatar
Thanks
Yes, its just the JDM MAP sensor and EvoScan. The data are plotted up in Excel. I have a template that I cut and paste into.
Old Apr 3, 2007 | 09:15 PM
  #63
96_LXR's Avatar
Noob question here . . .
Is there a way to get DLL to see the WGDC addition when logging?
Also it looks like I need to read through this post again,
When I logged today going to work the WGDC is at 78.43137255 through the entire log?
TIA,
Bob
Old Apr 4, 2007 | 12:12 AM
  #64
turbotiger's Avatar
https://www.evolutionm.net/forums/sh...9&postcount=37
Old Apr 4, 2007 | 11:40 AM
  #65
96_LXR's Avatar
Thanks Turbotiger
Old Apr 6, 2007 | 06:15 AM
  #66
nj1266's Avatar
Originally Posted by cij911
For others: My MWGDC are 127.5 from 500 to 2750, then 87 @ 3000, 45 @3500, then 20 from 4 - 4.5K, 22 @5000, 24 @5500, 62 @ 6K, 95 @6.5K, and 127.5 @ 7K....I made a #59 pill that is in the line from the turbo nipple going to the Tee and have a #59 bleeder infront of the BCS.
What do the pill # mean? Is there a sepcific chart that you are referencing? I read #59 and #56 in this thread, but I have no idea what that is.
Old Apr 6, 2007 | 06:36 AM
  #67
mrfred's Avatar
He's referring to drill bit sizes that use a number sequence:
http://en.wikipedia.org/wiki/Drill_b...rill_bit_sizes
Old Apr 6, 2007 | 08:15 AM
  #68
DangerousDan's Avatar
duplicate
I didn't refresh the page after reading so that ^ guy beat me to the punch.
Old Apr 12, 2007 | 07:55 PM
  #69
subaruwrx420's Avatar
First I wanted to say thank you for posting this because it's something I miss from logging the WRX.
Now, I'm using EvoScan v0.99...where do I paste the following in the data.xml file?
<DataListItem DataLog="Y" Display="WGDC" LogReference="WGDC" RequestID="86" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100"/>
Thanks.
Old Apr 12, 2007 | 08:12 PM
  #70
IIRC the only difference in where you put it is where it is on the graph menu and excel file. You can rearrange the data.xml file to reorder the excel file(or so it has been written) I haven't tried this myself yet, I just delete the empty columns.
Old Apr 13, 2007 | 06:03 AM
  #71
^^Alright, I added the code in the area where I saw all the other parameters listed and it worked! I also changed the order of the items without issue. Thanks.
Old Apr 13, 2007 | 05:32 PM
  #72
nj1266's Avatar
Anyone logging WGDC in Logworks? Can you share the formula that you are using?
Old Apr 13, 2007 | 11:34 PM
  #73
mchuang's Avatar
2nd gear pull:
4th gear pull:
Maybe try adjusting your mivec tables to aide spoolup.
Old Apr 19, 2007 | 06:47 PM
  #74
mrfred's Avatar
Thanks, but the MIVEC tables are already pretty aggressive. For the time being, I've gone ahead and adjusted timing and fuel to ensure that there is no knock when it hits the very high loads. I'll eventually try razorlabs 3-port BCS when he gets around to selling a kit.
Old Apr 19, 2007 | 11:55 PM
  #75
spdracerut's Avatar
Nice work guys! I never understood why some people are so enamoured by MBCs which is why I've spent a lot of time tuning the stock BCS system to my needs. In my case, running anything more than 1.4 bar of boost before 4k rpms gave me knock (tried pulling timing, adding fuel, nothing else completely got rid of the knock). So I set it up to run <1.4 bar until 4k, then turn it up to 1.5 bar. Can't do that with a MBC
