log boost with JDM MAP sensor (updated instructions)
Old Aug 9, 2007 | 08:38 PM
  #196
mrfred's Avatar
The boost definition in EvoScan is setup for the JDM MAP sensor, but it logs absolute boost. I just subtract off atmospheric pressure to give differential boost which is what people normally think of as boost.
Old Aug 12, 2007 | 09:04 PM
  #197
WhiteEvo05's Avatar
Quick question from the computer illiterati: <--Yes, I am a third person pluralality ...and I apologize in advance, this will probably be the first in many, many questions that many of you find woefully simple.
I did the additions to the 96940011.xml file for the JDM MAP sensor...
When I downloaded and saved the ROM I gave it a '.hex' suffix. I opened the ROM in ECUflash and no new category for the JDM MAP sensor...hmmm
I change the suffix on my saved ROM image to '.bin' and voila, it works...hmmm, again
Why is this?
Old Aug 14, 2007 | 09:34 PM
  #198
UCB's Avatar
UCB
aka gauge pressure
but we are not logging the same thing here....They added the extra sub rountine instead of just switching the current logging line from the factory map, so you can switch between the jdm and usdm map without having to change the data.xml file each time
Anyone else having issues with the JDM map sensor reading high
Mine read 28psi on 91 octane today@ 4k, however 0 knock
Old Aug 14, 2007 | 09:43 PM
  #199
RazorLab's Avatar
Mine is spot on.
Old Aug 14, 2007 | 09:49 PM
  #200
JohnBradley's Avatar
mine matches my gauges
Old Aug 14, 2007 | 10:02 PM
  #201
UCB's Avatar
UCB
strange, very strange, i remember nj had issues with is?
Old Aug 14, 2007 | 10:20 PM
  #202
UCB's Avatar
UCB
just read his post...it was just slightly laggy and maybe off my .5psi
I must have the stock turbo that could...it holds 22.6psi at 7k...24psi at 6k
I dont trust my boost gauge, ill have to install one of the .1psi resolutions gauges from work
Old Aug 14, 2007 | 10:31 PM
  #203
RazorLab's Avatar
UCB, I take it you calibrated the sensor with the ign on?
Old Aug 14, 2007 | 10:40 PM
  #204
UCB's Avatar
UCB
I didnt calibrate it, I just plugged in 14.4 for the gauge pressure offset. Is there some sort of other calibration required?
Old Aug 14, 2007 | 10:43 PM
  #205
RazorLab's Avatar
lol.
yes, you need to calibrate it with key on but car off. See what it reads. It should be close to 0 as possible. If not you need to change the setting.
Old Aug 14, 2007 | 11:23 PM
  #206
UCB's Avatar
UCB
k reads .002psi when the car is off, reads around -8.5psi while at idle
Old Aug 15, 2007 | 07:37 AM
  #207
mrfred's Avatar
Your MAP sensor values with the ign on / engine off and at idle are spot-on. Can you post a log or graph showing boost at WOT from 2300-7000 rpm?
EDIT: Can you also include 2-byte load?
Old Aug 15, 2007 | 09:55 AM
  #208
UCB's Avatar
UCB
Im playing with my boost settings so its very possible im hititng 28psi...timing is very conservative, perhaps explaining the low amount of knock considering what boost target im hitting. Only perplexing thing is why I didnt hit boost cut.
My laptop is being funky too, so need to iron that out, I havnt done the 2-byte load mod yet
Will try some things and log it again today
Old Aug 15, 2007 | 10:21 AM
  #209
nj1266's Avatar
One thing to keep in mind when logging with the JDMMAP sensor is that it picks up noise since it is mounted on the intake. So if you spiking to 28 psi, that is more than likely noise. Evoscan reports data as is and does not allow you to smooth out the noise from the boost.
When I log with the JDMMAP, I use Logworks and log directly from the sensor and not from the tactrix cable. Then I apply about 0.25-0.40 smoothing. This makes the boost almost the same as the GM 3 bar MAP sensor that is mounted on the firewall and does not pick up noise.
Old Aug 15, 2007 | 10:41 AM
  #210
UCB's Avatar
UCB
its not a spike like you would suspect from sensor noise. The boost profile actually looks amazing..if I was on C16
