log boost with JDM MAP sensor (updated instructions)
Old Jun 18, 2007 | 09:14 AM
  #121
mrfred's Avatar
Originally Posted by Evol.ved
How do I order one of these sensors?
Responded to your PM.
Old Jun 19, 2007 | 07:16 AM
  #122
RedV's Avatar
Any update on the P0401 code fix for the JDM MAP sensor on an Evo IX? Just threw the code again this morning on the way to work.
Old Jun 19, 2007 | 07:38 AM
  #123
mrfred's Avatar
Still working on it. Its a tough one to find though. I may have some news later this week.
Old Jun 20, 2007 | 01:38 PM
  #124
my-red-rs's Avatar
+1
I figured out the .xml file and changed the tables in EcuFlash (temp files for now) so I guess I'm ready... how much to 30005?
PM me please
Old Jun 28, 2007 | 05:48 AM
  #125
RedV's Avatar
OK, just threw the P0401 code again on the way to work. Not trying to be a pest, just wondering if there's any word on this yet? Thanks!
Old Jun 28, 2007 | 06:20 AM
  #126
mrfred's Avatar
I've been waiting for Bez to get back to me. Bez said he would look into it, but I haven't heard back yet.
Old Jun 28, 2007 | 02:08 PM
  #127
RedV's Avatar
OK. It was interesting, my car threw the P0401 code on the way to work. I then cleared it at work. Then it threw it again on the way home.
I've double checked (again) to make sure all my EGR hoses are connected and everything looks good. So it's gotta be related to the JDM MAP sensor.
Thanks!
EDIT: It threw it AGAIN! That's 3 times in 1 day!! If this keeps up I may have to put my USDM sensor back in.
Old Jul 2, 2007 | 07:57 AM
  #128
jmoudry's Avatar
I still have not had a code pop up since the very first day and then it went away before I could check it. It seems like weather conditions have alot to due with it.
Old Jul 9, 2007 | 09:03 PM
  #129
stockEvoIX's Avatar
Just curious, what kind of boost readings are you getting on a stock 9? I'm reading anywhere between -11 and +17.5.
Old Jul 9, 2007 | 09:07 PM
  #130
mrfred's Avatar
-11 seems about right. +17.5 seems a little low up top. What's the elevation where you live?
Old Jul 10, 2007 | 04:36 AM
  #131
tkklemann's Avatar
So the guys with the 2005 96940011 ROM's are doing OK with these?
If so, I am about ready to pick up one of these...
Old Jul 10, 2007 | 09:55 AM
  #132
kreionic's Avatar
Not really I had a friend throw the p0401 code on his 11 rom. He did the cel fix for the egr. It only disables the cel for the egr not disabling the egr itself
Old Jul 10, 2007 | 03:16 PM
  #133
stockEvoIX's Avatar
Thumbs up
Like 10' above sea level Guess I can increase my boost about 6 psi. Can I do that with the stock restrictor pill? If so, how? Thanks!
Old Jul 10, 2007 | 07:22 PM
  #134
mrfred's Avatar
Common, that's not really fair. The EGR cel is the only unresolved issue has been reported by more than one person. Its not a real EGR problem. The ECU just thinks there is an EGR problem. The value that the ECU uses to judge EGR performance just needs to be scaled to match the JDM MAP sensor. And not everyone is seeing the CEL. I think driving style is why some people see it and some don't. Rpms, throttle, speed, and other parameters all have to be within a set range before the EGR performance check routine will run.
Old Jul 10, 2007 | 07:24 PM
  #135
mrfred's Avatar
Can't be done with the stock restrictor pill(s). Check out some of the threads in the ECUFlash forum by Evo_kid and nj1266. And you may want to do a boost leak check before changing out the pills.
