Restrictor pill..
Old Mar 28, 2007 | 05:32 AM
urslo4n8's Avatar
Question Restrictor pill..
I recently had DYNOFLASH flash my ecu with great results. With removal of the restrictor pill, i see results of 22 psi with no tapering. QUESTION......For reliability purposes...with that basic flash i have; if i left the restrictor pill IN...what is the possible max boost i should see?? Will NON-REMOVAL of the pill confuse the flash as it was meant for removal to acheive 21-22 psi? Theres no problem gettin 92-93 octone here on Long Island.
Old Mar 28, 2007 | 07:00 PM
ixbreaker's Avatar
+1 i'd like to know the reliability of this too...but what mods are u running? do u have a data logger to reassure 22 psi is safe for ur set-up?
Old Mar 28, 2007 | 07:03 PM
tephra's Avatar
I think the restrictor pill only affects max boost - not the tapering.. this is done by the ECU...
my AUDM IX hsa a max boost of 19.8 PSI - thats stock ECU, with restrictor pill.
Old Mar 28, 2007 | 07:28 PM
urslo4n8's Avatar
i dont have any data logging devices BUT i had sent a list of mods to DYNOFLASH when i requested the flash, it pulls real strong and i never use anything less than 93 octane. I was actually wrong in one of my posts, it peaks to 22 then tapers to 18-19, which is nice
Old Mar 28, 2007 | 08:08 PM
RedV's Avatar
I actually just posted a similar question/thread this morning, found here...
https://www.evolutionm.net/forums/sh...d.php?t=260423
Maybe your thread will net some more answers/thoughts.
Old Mar 29, 2007 | 05:29 AM
honki24's Avatar
I'm def. not trying to be rude or mean... but these questions tend not to be answered in the EcuFlash forum... it doesn't really have anything to do w/ the tuning platform. The engine/drivetrain section would be great for this.
Old Mar 29, 2007 | 06:58 AM
urslo4n8's Avatar
Roger that kiddo no offense taken. The engine/drivetrain section it is...
Old Mar 29, 2007 | 08:42 AM
spdracerut's Avatar
The restrictor pill just limits the maximum boost by restricting the flow from the boost solenoid.
Your ecu won't care really. The two parameters that are related to this are the wastegate duty cycle and the boost desired engine load.
The wastegate duty cycle controls the boost. Using the same duty cycle value, leaving the restrictor pill in will result in lower boost. So if you put the pill back in, you'll just lower the amount of boost you'll run using all the same settings in the ecu.
There's a bit more to it dealing with the boost desired engine load and boost correction, but nothing major.
Old Mar 29, 2007 | 04:51 PM
eddie1681's Avatar
I have a quick questions, if I have a MBC I dont need to do the pill removal right
Thanks
Old Mar 30, 2007 | 05:44 AM
urslo4n8's Avatar
im pretty sure when you installed that MBc you replaced all of those lines anyway......hence the pill was removed....
Jush
Feb 23, 2014 06:40 PM
supersal
Jul 27, 2007 12:28 AM
k270kmh
Apr 20, 2006 07:08 PM
exhaust_note
Aug 11, 2005 09:44 PM
turboex
Dec 1, 2004 06:17 PM
