EcuFlash error message?
Old Apr 30, 2007 | 06:39 PM
DenisG's Avatar
Just installed EcuFlash for the first time. Started the program and got the following:
[07:34:37.062] Version 1.30.1095
[07:34:37.062] 8 memory models read.
[07:34:38.171] 145 ROM metadata models read.
[07:34:38.171] checksum module "subarudbw" loaded.
[07:34:38.171] flashing tool "wrx02" loaded.
[07:34:38.171] flashing tool "wrx04" loaded.
[07:34:38.171] flashing tool "sti04" loaded.
[07:34:38.171] flashing tool "sti05" loaded.
[07:34:38.171] flashing tool "mitsukernel" loaded.
[07:34:38.171] flashing tool "mitsukernelocp" loaded.
[07:34:38.171] flashing tool "mitsubootloader" loaded.
[07:34:38.234] error loading FTChipID.DLL
Is the error in the last line something I should expect to see?...
Old Apr 30, 2007 | 07:29 PM
codgi's Avatar
No. Have you installed the cable already though? From what I remember that dll is from the drivers for the cable...
Old Apr 30, 2007 | 08:09 PM
80210's Avatar
I'd re download it and install the tactrix drivers when it tries to
Old May 1, 2007 | 01:52 AM
SICK9's Avatar
I get same thing.
uninstalled and re d/l 3 times, still same thing..
anybody? or maybe get 1.29 instead ?
[02:15:39.430] Version 1.30.1095
[02:15:39.430] 8 memory models read.
[02:15:40.584] 145 ROM metadata models read.
[02:15:40.584] checksum module "subarudbw" loaded.
[02:15:40.584] flashing tool "wrx02" loaded.
[02:15:40.584] flashing tool "wrx04" loaded.
[02:15:40.584] flashing tool "sti04" loaded.
[02:15:40.584] flashing tool "sti05" loaded.
[02:15:40.584] flashing tool "mitsukernel" loaded.
[02:15:40.584] flashing tool "mitsukernelocp" loaded.
[02:15:40.584] flashing tool "mitsubootloader" loaded.
[02:15:40.600] error loading FTChipID.DLL
Old May 1, 2007 | 09:22 AM
DenisG's Avatar
fwiw... I do not yet have the Tactrix cable, so if there are drivers installed when it's connected that may be the issue...
Old May 1, 2007 | 08:02 PM
codgi's Avatar
Originally Posted by SICK9
I get same thing.
Have you had the cable installed on this machine before? And is this a clean install of 1.30 or did you have a previous version on before?
Old May 1, 2007 | 08:03 PM
codgi's Avatar
Quite possibly...let us know what happens when you get the cable.
Old May 1, 2007 | 09:51 PM
SICK9's Avatar
I dont have my cable yet either, so thats prob. it..
Let ya know when i do, and thx for help .
Old May 2, 2007 | 01:06 AM
cooliodb's Avatar
I am new to the ECUFlash and just recently downloaded the software and wanted to try it and got the same error. I should get my cable in the next two days and will try it again then. Thanks to you all.
Old May 10, 2007 | 04:34 PM
SICK9's Avatar
OK, so I got the cable now and I hooked it up and everything loads fine, but when i turn the read from ecu on i get this error message.
[02:15:40.584]No response to any known code
It tells me to check the error log, but i have no clue where that is.. any help with where error log is and what this "NO RESPONSE TO ANY KNOWN CODE" means.
Did a search and found out it maybe low voltage, so I hooked up charger to batt. and still same error message.
Any help will be greatly appreciated.
Old May 12, 2007 | 06:26 PM
SICK9's Avatar
ecu was locked..
DL'd ecuunlocker ,and its all good now, thx..
Old May 12, 2007 | 07:09 PM
codgi's Avatar
^^ Hmmm gotta watch out for these people who are locking the ecus .
lonestarevo83
Jul 15, 2011 07:20 PM
sweeney87
Apr 9, 2011 02:26 PM
waskarn
Lancer Engine Management / Tuning Forums
Jul 23, 2010 08:04 PM
GBAILEY472
Jun 24, 2009 08:25 AM
