Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Mar 14, 2009 | 05:25 PM
  #421
Danieln's Avatar
Thanks mrfred for reply.
The fact is that after reflashing I did'nt face idling problems at all until now.
I don't use yet tephra 88840017 v6 mode because I need to learn more about what setup I must do after reflash his mode.
Take care
Old Mar 16, 2009 | 09:36 AM
  #422
Nood1es's Avatar
well after 15k+ miles I've got a p0141 code thrown. Tried clearing it with a reader and pulling fuse but it comes back instantly. Could anyone please help? Thanks.
Edit: I still have the sensor plugged in. And my afrs seemed to be normal.
Old Mar 17, 2009 | 02:05 AM
  #423
Appauldd's Avatar
Nood1es......Your heater resistor is toast is my guess.
Old Mar 17, 2009 | 09:55 AM
  #424
Nood1es's Avatar
is there a patch yet for the entire removal of the rear 02 like the 9? Or just to remove the circuit heater bit.
Old Mar 25, 2009 | 03:03 PM
  #425
justin123456789's Avatar
yes we definitely need a patch to remove it all.....come on you electronic genius's do the evo world a favor!
Old Mar 25, 2009 | 03:36 PM
  #426
krazykorean84's Avatar
Tephra's rom mod v5.10 has a rear o2 sim and mr fred has given us the rear o2 heater circuit patch so what more do you really need? If you want it all combined into one unit, yes that would be nice but using both mods is not that hard at all.
Old Mar 25, 2009 | 03:47 PM
  #427
EvoBroMA's Avatar
OVER HERE!!! *waves*
https://www.evolutionm.net/forums/ec...sim-patch.html
Old Apr 12, 2009 | 11:39 AM
  #428
Danieln's Avatar
Originally Posted by tephra
guys 88580014 (AUDM IX) I also get the P0125 code... (coolant tempature wouldn't allow closed loop)
I do believe we are changing the correct code, because if I trace it through the bit we are changing is INDEED related to rear o2... strange!
Dave I have the same issue with my car.
How you fix this???
Thanks
Old Apr 12, 2009 | 04:10 PM
  #429
inco9nito99's Avatar
was fine for quite some time, (even readiness checks) and then all of the sudden a friendly wave from mister p0037 :-/.
Old Apr 12, 2009 | 06:15 PM
  #430
tephra's Avatar
Daniel - disabling the rear02 using periphey bit caused P0125 on my rom... so dont do that if you are
Old Apr 26, 2009 | 05:11 PM
  #431
troe666's Avatar
good work on this topic..
have been holding off til the p0125 issue is fixed.
f*ng CEL...
Trav
Old Aug 12, 2009 | 05:20 PM
  #432
kaj's Avatar
kaj
i googled and couldn't find a 50 ohm, 10 watt 5% tolerance resistor anywhere. did anyone find some??
Old Aug 12, 2009 | 05:34 PM
  #433
Just FYI, but there is really no need to do this mod if you have 88590015 or 96940011. Mr. Fred has come up with rear O2 heater sim patch here:
on post #59 and Acamus has created a mod that disables the Heater CEL located in the same thread on post # 267. I recommend reading the thread to fully educate yourself on these options.
Old Aug 13, 2009 | 09:47 PM
  #434
kaj's Avatar
kaj
aaaaah. will do. finally. some specific help. as opposed to "it's in the 300pg thread". haha. thanks. will start studying tonight.
also.. what about this one:
https://www.evolutionm.net/forums/ec...us-mrfred.html
in all reality.. when i smog, i'll be stock. i mean.. i need the stock exhaust and cat to pass smog.. so.. i guess needing to fool the ECU to pass emissions is.. impossible.
Old Sep 12, 2009 | 04:29 PM
  #435
BluesunsXIV's Avatar
will this patch work for any of the Xs yet, i need something to get rid of my cel and spacers arent working!
