Evo anti-lag ECU disassembly
Old Mar 13, 2008 | 03:36 PM
  #136
BarryC's Avatar
Originally Posted by Oracle1
You Hooligans
there are no excuses we are pure ricers,
sorry but I cant help it I want the popping and banging and shooting flames
Old Mar 13, 2008 | 03:38 PM
  #137
cossie1's Avatar
Petrol is damn expensive here, and well we might aswell set fire to the stuff in the exhaust aswell as the engine
Keeps the boy racers away from the rear of the car at the lights too
Old Mar 13, 2008 | 03:40 PM
  #138
BarryC's Avatar
good stuff Russ,
Old Mar 13, 2008 | 03:42 PM
  #139
silex's Avatar
USDM Evo IX ALS
Originally Posted by jcsbanks
<scaling name="RPMstatbyte" units="units" toexpr="x*31.25" frexpr="x/31.25" format="%.0f" min="0" max="11000" inc="1" storagetype="uint8" endian="big"/>
<scaling name="Timesecbyte" units="s" toexpr="x/10" frexpr="x*10" format="%.1f" min="0" max="25.5" inc="1" storagetype="uint8" endian="big"/>
<table name="ALS minimum vehicle speed to trigger" category="Turbo" address="1e12" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="Turbo" address="1e14" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="Turbo" address="1e16" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="Turbo" address="1e18" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="Turbo" address="1e1a" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="Turbo" address="1e1c" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="Turbo" address="1e1e" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="Turbo" address="1e20" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="Turbo" address="1e22" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="Turbo" address="1e24" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="Turbo" address="1e26" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Air injection time" category="Turbo" address="3fe0" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="66d8" type="X Axis" elements="9" scaling="RPM"/>
</table>
Originally Posted by JohnBradley
The air injection time map has some values that arent lining up for the IX. It appears that for the US IX the correct values are:
RPM-
6efa
Time-
3fde
Everything else seems to be pretty accurate though.
JB, the Time setting defaults it to milliseconds. I think we need to stick with the original Timesecbyte parameter. If you're refering to changing the Timesecbyte to an address of 3fde, then I follow. Timesecbyte has an address of 3fe0 which also appear to work.
First pic is how my windows look after pasting the XML code and changing the RPM address. Second one is after changing settings to simulate how the one looks in the OP: RPM in the 2k-6k range, zeroed out time, and random changed settings. Notice how all the changed boxes are grayed out? Only the RPM actually changed to their proper colors, but even those colors don't match what you guys have.
*EDIT* Changed Timesecbyte to 3fde and all the blocks zero'ed out and turned blue! Since all the other boxes are staying gray, it's leading me to believe the proper address values for these are not being referenced. I think we have more work ahead of us...
*EDIT2* 'ALS minimum vehicle speed to trigger' value can not be decremented and increases by 2 at a time. 'ALS minimum RPM to trigger' changes by a value of 31 to 33 every time. 'ALS minimum load to trigger' and 'ALS Load below which active' changes by 1.3 every time. Is this the same for everybody else?
Attached Thumbnails Evo anti-lag ECU disassembly-als-initial.jpg   Evo anti-lag ECU disassembly-als-change.jpg
Old Mar 13, 2008 | 03:47 PM
  #140
Youngsyr's Avatar
Originally Posted by silex
So only works at idle for you?
So far it's only when the cars on the rev limiter. I've been sent a set of more aggressive parameters to try, but I won't be able to do that until tomorrow.
If it works anything like the static ALS, it will be awesome, not just the noise, but 0.25 of boost!
How hot will my exhaust manifold need to be? I've only done a bit of normal road driving to get the coolant/oil temp up to operating temps and then done some WOT runs, I wonder if it's just not hot enough unless you go on extended runs?
Old Mar 13, 2008 | 03:53 PM
  #141
Oracle1's Avatar
Some one who has no SAS but the correct settings has the ALS working. Must be worth a try.
Old Mar 13, 2008 | 04:00 PM
  #142
silex's Avatar
Do you have an EGT sensor to check those temps? More than ever, it will be important if messing with ALS. You do not want those to rise above 1100c or so for very long. Just to give you an idea, most tunes are done to ensure EGT's don't go above 900c. Although this is just a rule of thumb and most people don't use EGT exclusively as a a way to tune, but rather as a way to ensure a certain temp threshold is not surpassed.
Really, how is this possible? You sure they didn't mess with their timing and fuel maps?
Old Mar 13, 2008 | 04:04 PM
  #143
Youngsyr's Avatar
You're probably right, mate. I have a Defi VSD head up display which I can easily add an EGT sensor to, but I would prefer a sensor I can log in Evoscan, does anyone know of one?
Old Mar 13, 2008 | 04:07 PM
  #144
cossie1's Avatar
What are the settings though ???
Old Mar 13, 2008 | 04:10 PM
  #145
Youngsyr's Avatar
Our French friend who posted the Evo 7 maps mentioned that he knew of EDM Evos with ALS working and no SAS. I'll ask him to expand, I thought he just meant they'd mapped in pops and bangs to the fuel/timing maps, rather than use the EGR?
Old Mar 13, 2008 | 04:18 PM
  #146
silex's Avatar
Which is what I suggested you should clarify. There is no way the ALS-specific settings can be used without the SAS hardware. Can somebody check out my post# 139 and clarify what you can? Also need a fellow USDM Evo IX owner to help me to replicate my issue and see if we can locate the proper addresses for the rest of the windows (if need be). Is there a list of memory addresses we can dig through or how do you guys locate these?
Old Mar 13, 2008 | 04:40 PM
  #147
kkarim's Avatar
Standalone ECUs such as Motec use a throttle kicker which is basically as solenoid that keeps the throttle plate open to allow air to go through, instead of using the SAS.
I believe it's possible to have some sort of anti lag using the a throttle kicker, retarded timing, and an extra rich mixture..
Old Mar 13, 2008 | 05:49 PM
  #148
silex's Avatar
A throttle kicker is still hardware and as such could be bunched in with my reference to SAS hardware. Again, we are trying not to mess with the default timing and fuel maps. It's a crude way to get ALS working. Nobody will run an ALS map 24/7 unless it's set up like the factory ECU has it setup, through SAS hardware. We have the software there already so might as well get the hardware and make it work.
Can't wait to see results from some of our overseas brothers!
Old Mar 13, 2008 | 09:06 PM
  #149
nod911's Avatar
A guy I know that does rallying has told me before to drill the banjo's out by 1.5mm or to 1.5mm (will need to check) to get the system to work better and smoother.
Yep I have been told the same thing by another local.
Also tested this and had some pretty unimpresive results as well.
theres a few locals testing this soon over here too
http://www.evolutionoz.net/forum/php...ic.php?t=19160
Old Mar 13, 2008 | 10:07 PM
  #150
JohnBradley's Avatar
I seem to have gone back to work and come back only more confused.
SO..
Youngsyr,
To recap exactly what are the conditions that you have set to make the SAS work without the SAS hardware? No specifics if you cant share them, but I missed the connection between the SAS software and then a normal stationary rev limiter I think. .25 bar between shifts or just at a standstill with nothing else going on?
JB
