Thoughts on my knock?
Old May 8, 2007 | 07:21 PM
AutoXer's Avatar
Is my timing still too far advanced? My AFR looks OK, right?
Code:
Time	Timing	RPM  KnockADC    AFR    Knock	Load	Throttle
14453	16	2469	18	13.85	4	110	100
14578	15	2531	28	13.49	4	113	100
14703	14	2562	27	13.39	4	116	100
14844	14	2625	30	13.01	3	119	100
14969	14	2688	31	12.94	3	123	100
15094	14	2750	32	12.67	3	126	100
15219	13	2781	20	12.58	3	130	100
15344	12	2844	29	12.52	3	135	100
15485	11	2938	22	12.61	3	140	100
15610	10	3000	33	12.85	2	146	100
15735	9	3062	46	12.98	2	152	100
15860	8	3156	22	13.02	2	81	100
15985	7	3188	32	13.1	2	171	100
16125	6	3281    41	13.02	2	180	100
16250	5	3375	39	13.04	2	196	100
16375	5	3469	67	12.73	2	207	100
16500	5	3562	36	12.54	1	218	100
16625	3	3656	35	12.16	1	230	100
16750	3	3750	72	12.04	1	233	100
16891	4	3875	63	11.94	1	228	100
17016	5	3969	54	11.8	1	225	100
17141	4	4094	12	11.83	1	227	100
17266	4	4219	18	11.64	1	231	100
17391	4	4281	20	11.67	1	234	100
17531	4	4406	16	11.44	1	233	100
17656	4	4500	18	11.38	1	229	100
17781	4	4594	36	11.23	1	230	100
17906	4	4719	14	11.27	1	234	100
18031	4	4812	24	11.22	5	234	100
18172	4	4906	30	11.25	5	232	100
18297	4	5000	25	11.16	5	228	100
18422	4	5094	36	11.32	5	225	100
18547	4	5188	28	11.36	5	225	100
18672	5	5281	28	11.22	5	227	100
18797	5	5375	36	11.26	4	225	100
18938	7	5469	30	11.3	4	224	100
19063	7	5562	49	11.25	8	226	100
19188	4	5656	22	11.26	8	228	100
19313	4	5750	34	11.22	8	227	100
19438	5	5844	30	11.11	8	224	100
19578	6	5938	46	11.05	8	222	100
19703	6	6031	32	11.17	7	223	100
19828	6	6094	26	11.1	7	222	100
19953	7	6188	26	10.97	7	219	100
20078	7	6281	54	11	7	219	100
20219	8	6375	45	11.13	7	220	100
20344	8	6438	35	11.07	7	218	100
20469	9	6500	30	11.1	8	215	100
20594	10	6593	44	11.16	8	211	100
20719	11	6688	31	11.08	8	211	100
20860	11	6750	30	11.11	8	209	100
20985	11	6812	45	10.97	8	209	100
21110	11	6906	39	11.04	8	211	100
21235	12	7000	91	10.91	7	209	100
21360	12	7031	43	10.97	7	207	100
21500	12	7125	51	10.97	7	209	100
21625	13	7188	49	10.86	7	209	100
21750	13	7250	60	10.91	7	208	100
A few minutes later:
Code:
110578	12	2562	20	12.95	1	123	100
110703	12	2625	27	12.74	1	127	100
110844	11	2688	19	12.73	1	130	100
110969	10	2719	20	12.55	2	134	100
111094	10	2781	17	12.7	2	139	100
111219	9	2844	22	12.99	2	143	100
111344	8	2906	28	12.98	1	150	100
111485	8	2969	43	13.01	1	156	100
111610	7	3000	35	12.99	1	163	100
111735	5	3094	33	13.07	1	172	100
111860	5	3156	27	13.02	1	182	100
111985	4	3250	26	13.01	1	196	100
112110	3	3312	29	13.04	0	208	100
112250	4	3406	42	12.69	0	220	100
112375	3	3500	51	12.51	0	231	100
112500	3	3562	37	12.3	0	232	100
112625	4	3688	32	12.11	0	223	100
112750	4	3781	51	11.89	0	223	100
112891	4	3875	54	11.86	0	229	100
113016	4	3969	65	12.01	0	228	100
113141	5	4062	72	11.79	0	225	100
113266	4	4156	20	11.73	0	231	100
113391	5	4250	14	11.66	0	232	100
113531	4	4344	39	11.48	0	233	100
113656	5	4438	13	11.36	0	231	100
113781	6	4531	31	11.3	0	225	100
113906	5	4625    33	11.35	0	232	100
114031	5	4719	27	11.41	0	233	100
114172	5	4812	24	11.2	3	231	100
114297	5	4906	36	11.11	3	232	100
114422	5	5000	29	11.2	3	230	100
114547	5	5094	30	11.2	2	225	100
114672	5	5188	35	11.22	9	222	100
114797	3	5281	58	11.19	9	226	100
114938	4	5344	39	11.26	9	226	100
115063	4	5438	23	11.16	9	226	100
115188	4	5500	44	11.14	9	224	100
115313	4	5594	27	11.11	8	224	100
115438	4	5688	33	11.23	8	226	100
115578	5	5750	17	11.2	8	224	100
115703	5	5844	31	11.02	8	223	100
115828	6	5938	31	11.05	8	223	100
115953	6	6000	38	10.95	8	222	100
116078	6	6094	48	10.98	8	221	100
116219	7	6156	32	10.94	7	222	100
116344	7	6219	54	10.98	7	220	100
116469	8	6312	84	11.02	9	219	100
116594	8	6375	43	10.98	9	222	100
116719	9	6438	48	10.94	9	217	100
116860	8	6531	26	10.91	11	214	100
116985	8	6625	21	11.02	10	213	100
117110	9	6656	36	10.92	10	213	100
117235	10	6750	53	10.94	10	211	100
117360	10	6812	44	10.79	10	209	100
117485	10	6875	35	10.88	10	209	100
117625	11	6938	69	10.76	10	209	100
117750	12	7031	31	10.94	9	208	100
117875	12	7062    32	10.78	9	208	100
118000	12	7125	34	10.78	9	207	100
118125	12	7188	40	10.73	9	208	100
118266	12	7250	51	10.7	9	208	100
118391	12	7312	38	10.69	9	207	100
118516	12	7375	65	10.67	8	206	100
118641	14	7406	35	10.57	8	203	51.765
Old May 8, 2007 | 07:29 PM
RedV's Avatar
I can't comment on your timing, but just comparing it to my logs... yikes. Just my opinion, but if I was seeing that much knock I would definitely STOP driving my car. Then maybe pull some timing and maybe add a little fuel. Try and get down to 3 or less knock counts across the rev range.
Looks like you're more modded than I am, and I am by no means an expert tuner, but with that much knock you've gotta be losing power as a result of the ECU pulling timing to protect your engine.
Old May 8, 2007 | 08:02 PM
iTune's Avatar
post your high octane ignition tables. what octane fuel are you using?
CJ
Old May 8, 2007 | 08:27 PM
TouringBubble's Avatar
the 2 and 3 degree jumps in the first log are probably lending to the knock problem. You aren't pushing very much timing. Those numbers might be an issue if you are running 91 though.
Old May 8, 2007 | 08:29 PM
TTP Engineering's Avatar
You do not need to share your high octane map with the forum.
Your fueling map needs work though. You are on the lean side before and up into peak torque.
Old May 8, 2007 | 08:32 PM
iTune's Avatar
The ECU is pulling timing throught the pull....with all that knock. We would have to do the math on those numbers to see what his actual timing values are.
Because i'm lazy, i figured i would just ask him to post his ignition table. lol
CJ
Old May 8, 2007 | 08:37 PM
iTune's Avatar
Was he tuned by you(or by another vendor)? There is nothing wrong with him posting his maps in order for us to help him. Trust me, i doubt anybody wants to "steal" his ignition timing....lol. I swear. You vendors kill me sometimes...i mean all the time.
The guy wants help....the only way i can help is if i know all the information. Besides, anybody can figure out his actual timing values by doing the math.
CJ
Old May 8, 2007 | 09:08 PM
C6C6CH3vo's Avatar
Bad gas
Old May 8, 2007 | 09:11 PM
CJ
His problem is his fueling, not his ignition timing.
I am not convinced that you are qualified to help him, especially as you have demonstrated that you have overlooked the data already provided.
Old May 8, 2007 | 09:15 PM
Ph3n1x's Avatar
I agree with TTP, his AFR;s are way off. He needs to get that corrected before looking into the ignition side. Once you start knocking....it just keeps going and going., its like a bad disease.
Old May 8, 2007 | 09:23 PM
JohnBradley's Avatar
I concur as well. Fueling doesnt show compensation for the pump, tip-in/peak torque is EXTREMELY lean for pump gas, and the load is peculiarly low. I would surmise that you are currently boosting less than stock OR if you are boosting at an indicated stock level you have some gremlins.
What octane fuel and what boost level? When was the last time you looked inside your intercooler?
Old May 8, 2007 | 09:31 PM
Ph3n1x's Avatar
His load is not too low, just conservative, looks to be 20-21psi with those numbers.
Old May 8, 2007 | 09:52 PM
For those mods his load is somewhat low actually. A bonestock VIII runs in the 220 range +/- based on air conditions for peak load. Conservative is definitely true, and is partly why I find the knock (other than being fueling induced) rather odd. That being stated, I am still curious for his answers.
Old May 8, 2007 | 09:55 PM
andenbre's Avatar
have you done a proper free air cal lately ? I was having problems with high knock with conservative timing and fuel only to find my LC1 was reading almost a full 1.0 afr richer than actual. even though it swept properly (14.5-14.8) in closed loop it was reading mid 11 afr even though the dynos wb was reading mid 12 afrs. after a good cal it read accurately.
I hit mid 250 load cells at 20 psi on my car (map and 2 byte logged) so he may be in the 18 psi range.
Old May 9, 2007 | 03:17 AM
AutoXer's Avatar
Here's the High Octane Fuel and Timing maps. I'm using 93 octane. It's hitting about 20psi on my autometer gauge.
I did do a free air calibration on the O2 sensor but that's been a couple of months ago. I'll try to calibrate it again today.
I've NEVER looked inside my intercooler, but I do have a catch can. Perhaps I should "break the seal" and give it a look.
Attached Thumbnails Thoughts on my knock?-93octanehioctanefuel.jpg   Thoughts on my knock?-93octanehioctanetiming.jpg
