272/272 + Mivec = smooth Idle??
Old Jun 1, 2007, 10:34 AM
awdboosted's Avatar
Has anyone played with Mivec at idle to calm down aggressive cam? I have Cosworth 272/272 in my Evo 9. I tried to increase overlap and the car just idle worse. I was thinking about retarding timing and increasing overlapping?? Has anyone else had better results?? The idea is to get rid of the CE light..
Old Jun 1, 2007, 02:11 PM
Tuner@Swift's Avatar
I have the GSC 280's and my idle is just as smooth as stock with the intake cam set @ 0 from 500-1000rpm. I did advance the timing to 16.2 to see what kind of effect it had, all it did was add more lope to the idle.
Old Jun 1, 2007, 02:35 PM
awdboosted's Avatar
i'm gettting miss fire code. Maybe I should try retarding timing?? What RPM are you idle at??
Old Jun 1, 2007, 03:01 PM
Pd1
Pd1's Avatar
I run these with 9* of ignition advance and with 0's in the idle cells on the VVT map and it's pretty smooth (just a tiny bit lopier than stock). No trouble codes.
If you do this and still experience a very rough idle, you may have injector scaling/latency issues to resolve. Check your "O2 Feedback" trim at idle as a start.
Old Jun 1, 2007, 03:04 PM
JohnBradley's Avatar
You can also crank up your target idle some to compensate. Like PD1 said increasing idle timing will help. You cant actually retard the intake cam as 0* is all the further back it goes.
JB
4WS Tuning's Avatar
email me your map, i'll fix the idle... Its an easy fix
autounionag@aol.com
Cheers!
Old Jun 1, 2007, 03:49 PM
awdboosted's Avatar
autounionag@aol.com
Cheers!
I'm going to try fix it first myself because I'm try to learn this software. I've tuned with AEM but this is completely different because I'm used to PSI and not (Engine load %)
This help is greatly appreciated.
Old Jun 1, 2007, 03:55 PM
4WS Tuning's Avatar
np man anytime!
Old Aug 3, 2008, 10:57 AM
23r0k001's Avatar
subscribed...
Old Aug 4, 2008, 06:58 AM
inco9nito99's Avatar
Mike, feel free to call me bud!
Old May 22, 2015, 01:09 PM
Pyatka-ubiyca's Avatar
anybody resolved this problem ? I have similar config, but idle in range (990 - 1050) and idle no smooth
Old May 24, 2015, 11:34 AM
Raptord's Avatar
Increase timing at idle (10-12° for example) with no MIVEC overlap for a smoother idle, I have the Cosworth M2's as well and hey can idle pretty smoothly.
Old May 24, 2015, 11:43 AM
doghouse's Avatar
I had tomei 280 and it was like stock with aem v1 but my cams now are very hard to tame
Old May 26, 2015, 08:56 AM
mrfred's Avatar
mivec can be set as low as -1.2 deg. every bit helps for big cams.
uneekvisions
Jul 26, 2017 10:26 AM
Fourdoor
16
Jun 3, 2010 05:11 AM
SmokinJoe
51
Feb 16, 2006 10:09 AM
Huscroft6
11
Sep 18, 2004 06:48 PM
SILVER SURFER
14
Mar 16, 2004 04:52 PM
Quick Reply: 272/272 + Mivec = smooth Idle??
