What is the max load are u seeing guys?
Old Dec 29, 2008 | 01:16 PM
  #76
Mellon Racing's Avatar
let me know what to change and I'll be more than happy to be the test mule...I'll be putting race gas in the car soon and want to crank the boost way up so it's important that I have good control over the fueling
Old Dec 29, 2008 | 07:59 PM
  #77
RazorLab's Avatar
Originally Posted by Mellon Tuning
I tried this while at lunch, still pegging 380kpa, I raised the boost even more and it's peaking 380kpa but holding that value further out to higher rpms. I'm logging 2byte load btw.
This doesn't help but something I have been noticing is that you keep saying load is in kpa when it isn't.
If you where running 380kpa you would be running approx 40psi
Old Dec 29, 2008 | 08:47 PM
  #78
JohnBradley's Avatar
Originally Posted by jcsbanks
Disappointed it doesn't work on the 8 when it appears to on the 9. There are some code differences on the 8, I'll look into it further.
If any high torque 8 or 9 owners can test and report back, that will help!
Let me double check what i was seeing but I was getting 399 for more than one cell. I have run into reporting errors with EvoScan so its possible that it was 380 and then spiked with an error.
My data is possibly flawed.
Old Dec 30, 2008 | 02:15 AM
  #79
jcsbanks's Avatar
Thanks, if I know that the 9 doesn't work then I can go back to my own ECU disassembly which I know best of all. If the 9 does work and the 8 doesn't I need to hunt for different stuff.
Old Dec 31, 2008 | 09:37 AM
  #80
any news JB?
Old Dec 31, 2008 | 10:59 AM
  #81
Not yet, I havent had a chance to play with it again. I have to rescale the injectors when I do it and I foolishly didnt save the last map. Between that and the recent blizzard up here in the NW I have been kind of stuck (cant wait till we get a dyno).
Old Dec 31, 2008 | 12:40 PM
  #82
understandable JB... jcsbanks, any chance of pressing on with the evo 8 troubleshooting in light of this? I really don't want to put this AEM EMS in that I have sitting here if I don't absolutely have to
Old Jan 1, 2009 | 05:51 AM
  #83
jcsbanks's Avatar
I'm presently trying to work through the huge volume of code that deals with the MAF to fully understand all the implications before converting to speed density. If there is another limiter in there I should find it in this process, but maybe not quite as quickly as you need. I really need to know if the IX is sorted before I can make any sense on the VIII. I can't hit this sort of load on my IX or any IX I have access to to find out if the limit is fixed.
Old Jan 1, 2009 | 11:23 AM
  #84
Jim in Tucson's Avatar
OK, I may be missing something simple here, but how are you'll getting around the 319 load fuel cut limit?
Old Jan 1, 2009 | 11:28 AM
  #85
boostedwrx's Avatar
I usually have to wait a few days before max load
Old Jan 1, 2009 | 11:47 AM
  #86
ok, I'll press on with the 380 clip and just tune around the issue for now. I'll probably get some race gas for next weekend and see how it behaves
thanks very much for your efforts...further blurring the line between the stock ecu and stand alone is good stuff
Old Jan 1, 2009 | 11:53 AM
  #87
GST Motorsports's Avatar
Just up the Boost Cut Delay Timer
Old Jan 1, 2009 | 02:57 PM
  #88
DUH! I figured it would be something simple.
Old Jan 2, 2009 | 10:51 AM
  #89
psphinx81's Avatar
this would be fantastic if someone can figure this out by april/may
im going to max out the ECU hardcore on the HTA86
Old Jan 2, 2009 | 10:56 AM
  #90
ok, everyone stare at jcsbanks
