HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
Old Oct 20, 2011 | 01:21 PM
  #496
RazorLab's Avatar
Originally Posted by prowakeskater
Wait, my pigtail isn't labeled, so how do I connect the wires?
Doesn't matter. There is no polarity.
Old Oct 20, 2011 | 01:44 PM
  #497
ed1380's Avatar
How much different is this if you want to do it on a dsm with ecuflash?
Old Oct 23, 2011 | 10:37 PM
  #498
markyang83's Avatar
I am trying to install a 3 port solenoid into my jdm 88570008 evo, how ever I find out the car has twin solenoids set up. How should deal with this please.
Many thanks
Mark
Old Oct 24, 2011 | 08:45 AM
  #499
fostytou's Avatar
EvoM Community Team
Many thanks
Mark
Checking out a few of th posts about this that are already here would be a good start, but then you would use the primary solenoid pigtail and tune the tables for the primary solenoid.
Old Nov 3, 2011 | 07:21 PM
  #500
markyang83's Avatar
Hi mate
Thinks fo your help, I guess my 3 port is working fine now. However I can't log the WGDC Correction though Evoscan. Do you have any idea what is the correct MUT address for this? Also do you know if there is any patch to modify the load based boost control to psi based?
Cheers
Mark
Old Nov 7, 2011 | 07:43 AM
  #501
fostytou's Avatar
EvoM Community Team
Hi mate
Cheers
Mark
Really, please search! There should be a MUT address breakdown in the ecuwiki (in my sig). There is a thread on psi boost control... you'll need to see if there is a patch for your ROM ID.
Old Nov 13, 2011 | 01:50 AM
  #502
TJung's Avatar
Hello, it's me again. My car is overboosting now. I have a Grimmspeed 3-port with BEC and BDEL tables zeroed out. I was using to steering my boost only WGDC table. Could this be cause of overboosting? My car was tuned in summer, now we have low temps outside...
Old Nov 13, 2011 | 02:07 PM
  #503
CDrinkH2O's Avatar
Why did you zero out TBEC? It is there to help you because it reduces WGDC if you overboost .
Old Nov 13, 2011 | 10:31 PM
  #504
TJung's Avatar
In summer, when I tuned the car, I didn't saw any negative things with zero out this table. I was using only WGDC table just because of my lazy .
Now we have about 5 celsius in Poland, so my car is obverboosting :/
Old Nov 23, 2011 | 07:56 PM
  #505
fostytou's Avatar
EvoM Community Team
Yes, that is the cause. Enable TBEC and create a map for winter. Better yet, use tephramod and you can reduce WGDC based on IAT (a godsend in my personal opinion).
Old Nov 24, 2011 | 01:58 AM
  #506
tephra's Avatar
you think I should implement it for TephraXMOD?
Old Nov 25, 2011 | 07:19 AM
  #507
TJung's Avatar
Hey. Thanks for answer. I just back to my previus settings and it's better. I am using v5.10 and didn'y know about WGDC ->IAT correction . I must buy some IAT sensor then
Old Nov 25, 2011 | 10:31 AM
  #508
Boosted Tuning's Avatar
No need to buy anything. It uses the air temp sensor that is in the stock MAF.
Old Nov 25, 2011 | 09:02 PM
  #509
TJung's Avatar
oops didn't know
Can someone put some examples how should I set it ? I am blind or I don't have any table related with this :/
Old Nov 26, 2011 | 03:02 AM
  #510
vd's Avatar
vd
This is how it is setup in my car. I don't think it's perfect, but you get the idea.
oops didn't know
