HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
Old Jul 14, 2010 | 02:16 PM
  #451
VGergo's Avatar
ok, I will check the boost leak.
Old Jul 14, 2010 | 03:25 PM
  #452
Boosted Tuning's Avatar
Originally Posted by leecavturbo
I'm sure you'll not get 24psi@7k anyway
you should beable to improve that taper tho
looks like you have a leak to me your correction doesn't move off max
His correction doesnt move because of some ROM/logging issue, not a boost leak.
Even if he had a boost leak, correction would still work.
But it is a great idea to make sure the car is boost leak free before trying to tune.
Old Jul 14, 2010 | 04:02 PM
  #453
VGergo's Avatar
Where shoud I search the problem to able to log right load error and wgdcc ? In the Mut tables ?
I have the same problem with V7 94170015 and with 96530006 too..
I changed only the 2byte load rpm and airflow settings in the MUT table.
Old Jul 14, 2010 | 06:14 PM
  #454
Just double and triple check everything. If you did mods, like JDM MAP or direct boost control, go over all of it again and double/triple check it. Make sure to check addresses, scalings, etc.
Old Jul 16, 2010 | 03:13 PM
  #455
VGergo's Avatar
In the tephra v7 topic i found similiar problems when searched on " load error" .
In the ecu based direct boost control topic mabye there is how to solve it. I will try it.
Old Jul 16, 2010 | 03:52 PM
  #456
nonschlont's Avatar
if your set up for ecu "direct boost control" you should NOT be using any of your "load" maps. Boost adder / correction / Boost maps all have their own "psi" maps.
Old Jul 20, 2010 | 10:03 AM
  #457
element26's Avatar
about to install one
Old Nov 6, 2010 | 06:28 AM
  #458
ajstefanacci's Avatar
Why does the solenoid hook to the intake? If I'm not mistaken, the compressor should hook to the input on the solenoid, the normally open port should hook to the top of the waste gate to hold it closed while boosting, and the normally closed port should hook to the bottom of the waste gate opening it when triggered by the computer.
I believe the way the picture shows it will work similar to stock and not hold anymore
Someone correct me if I'm wrong or explain what I'm missing
Old Nov 16, 2010 | 04:10 PM
  #459
VGergo's Avatar
Do you have part throttle problem on 3 port ? Like cruesing on the high way exspecially up on hill and just wanna hold a constant speed like 100mph and the bov open or the feeling is like this and the car is flutter. With synapse bov it is much better- softer than ssqv or stock plastic bov mount reverse but also can feel it some time.
Old Nov 23, 2010 | 12:39 PM
  #460
VGergo's Avatar
Nobody has problem with part throttle accelerating on the 3 port ? The car is working wonderful @ wot but sometimes on part throttle in 4th 5th 6th gear accelerating from 2500-4500rpm the car is jerking on a moment, like the turbo trying to push too much air and the bov is opening.. Can I lowering the part throttle boost without effect on the wot ?
I'm on Synapse dv, it is in push mode and A+B port connected. The preloader spring is in stock setting. Maybe I coud adjust it too .
Here is my setting and wot boost curve, looking for any idea :
Old Nov 25, 2010 | 09:32 AM
  #461
vd's Avatar
vd
I believe the problem is caused by WGDC=100% under this load parameter. To check - zero out the value and see whether it gets better.
Old Nov 29, 2010 | 10:23 AM
  #462
fostytou's Avatar
EvoM Community Team
That is your answer
Also, since you didn't specify make sure you have port C connected if you have an older model Synapse. This port is internally routed on newer models.
Old Nov 29, 2010 | 10:48 AM
  #463
tscompusa2's Avatar
VGergo, also if you watch your boost gauge it will occur once you reach a certain boost level correct? if so i would lower the wgdc in those gears only to not pass the certain boost that causes the surge. Its a common thing with a 4 cylinder engine with lots of airflow being forced into it with not enough load/RPM for the engine to breath in the air.
Old Nov 29, 2010 | 10:49 AM
  #464
mullen's Avatar
sounds like you've got this figured out
Old Nov 29, 2010 | 12:03 PM
  #465
VGergo's Avatar
okay guys i will try to zero out the wgdc 100% under X load table and see it. But now the car is not so bad Honestly i wouldnt like to lowering the wgdc, maybe if the table is not help on the issue I will try to improve the engine ve by cam upgrade.
