Fuel trim adjustments
Old Aug 4, 2007 | 08:16 PM
AutoXer's Avatar
Just a random comment really... I noticed the other day that the cruise long term fuel trim seems to make adjustments every 4 minutes. Anyone else notice this or have any comments on it?
Old Aug 6, 2007 | 07:40 AM
chmodlf's Avatar
If you are using evoscan, with one of the recent versions he switched the short and long term fuel trims. I have posted this issue a while ago. I am not sure if this was by design or a mistake. Mitsulogger as the trims the way evoscan used to be.
Old Aug 6, 2007 | 08:32 AM
AutoXer's Avatar
I'm using ECUedit. However, I'm looking at the three stock MUT fuel trim values. One stays at zero all the time, one changes at idle and the other changes during cruise. I didn't think MUT gave a short term fuel trim value? If so, what's the Request ID?
Old Aug 6, 2007 | 04:08 PM
nothere's Avatar
just in case,
the "zero all the time" is your long term trim, I suppose eventually it will move
then there is short term at idle
and mid term trim at cruise.
they move at odd times as though some variable has been knocked over, but normally during an extended period of whatever type driving you are doing.
during a cold start they will try to "fix" the afr and then correct itself after the car has warmed up, so the trims move, in a small range, regardless of how perfect you have them set.
Old Aug 7, 2007 | 01:53 PM
chmodlf's Avatar
Request ID for fuel trim:
Short = "0C"
Mid= "0D"
Long = "0E"
Old Aug 7, 2007 | 02:00 PM
l2r99gst's Avatar
Short = "0C"
Mid= "0D"
Long = "0E"
0C = LTFT Lo
0D = LTFT Mid
0E = LTFT High
0F = STFT
LTFT is long term fuel trims. STFT is short term fuel trim, sometimes called O2 feedback.
Eric
Old Sep 23, 2007 | 08:33 AM
mrfred's Avatar
Originally Posted by l2r99gst
0C = LTFT Lo
0D = LTFT Mid
0E = LTFT High
0F = STFT
Eric
What is the difference between the Lo, Mid, and High LTFTs? Is it different load regimes? Different RPM regimes?
Old Sep 23, 2007 | 09:03 AM
l2r99gst's Avatar
I haven't done the disassembly myself, but I believe it is different airflow ranges. The cutoffs make the Low for idle and the mid for normal cruising. The High would be very high airflow cruising, which wouldn't normally be met during daily driving.
Perhaps someone who has disassembled the routines can tell us for sure.
Eric
Old Sep 23, 2007 | 09:06 AM
mrfred's Avatar
Eric
Maybe I'll take a look myself today. Just have to go get my PC from work.
Old Sep 23, 2007 | 10:02 PM
TouringBubble's Avatar
It seems to be different airflow ranges as mentioned above.
nicolassabra
Sep 19, 2013 04:02 AM
Appauldd
Jan 8, 2010 06:37 PM
def1
Aug 2, 2009 07:51 PM
SkyNight
Mar 15, 2009 09:13 AM
evopower1021
Jun 13, 2007 09:58 AM
