ECU boost control mods
Old Mar 19, 2008 | 08:47 AM
  #196
mrfred's Avatar
Originally Posted by bnice01
can you use 94170008 mod for rom ID 94170014?
If the right stock values show up, it will work. I'm about half way through the direct boost control mod for the 94170014. Should have it done in the next day or so.
Old Mar 19, 2008 | 09:00 AM
  #197
jhanksevo's Avatar
what about 94170015 any kind of timeframe
Old Mar 19, 2008 | 09:03 AM
  #198
bnice01's Avatar
hanks this is for ecuboost using load, you want direct boost control using psi following your jdm map sensor. I use this mod since I dont have a jdm map sensor
this mod (direct boost control) is what your talking about or need
https://www.evolutionm.net/forums/sh...d.php?t=293981
Old Mar 19, 2008 | 09:04 AM
  #199
bnice01's Avatar
Naw the right stock values didnt show up but thanks for the info
Old Mar 20, 2008 | 11:30 PM
  #200
mrfred's Avatar
Added instructions for USDM Evo VIII 94170014 and 94170015.
Old Mar 21, 2008 | 05:50 AM
  #201
bnice01's Avatar
You Are The Man Mrfred Thank You
Old Mar 21, 2008 | 09:49 AM
  #202
DCsleeper's Avatar
^+1
Can't wait to try this out.
Old Mar 21, 2008 | 03:26 PM
  #203
h101171's Avatar
Rom 88840013
That will make it easy to adapt to that ROM, so I can do that when I get an 88840013 ROM. Its probably better for the 88840013 guy to switch to the 88840016 ROM though as I imagine that tephra will not be making a prepatched 88840013 ROM.
Whats going on in this affaire. I have the same ROM.
Greetings
Marcel
Old Apr 7, 2008 | 01:39 PM
  #204
evo828's Avatar
Rom 96530006
For those using 96530006:
EDM Evo VIII 96530006
Add the following lines to your ROM file:
----- (don't add the "-----")
<table name="Variable for Boost Control" category="Turbo" address="2025e" type="1D" level="1" scaling="Hex16"/>
<table name="Load Error RAM Addr" category="Turbo" address="20252" type="1D" level="1" scaling="Hex16"/>
<table name="Load Error RAM Addr in Boost Error Table" category="Turbo" address="6bfa" type="1D" level="1" scaling="Hex16"/>
<table name="WGDC Correction interval #1" category="Turbo" address="1a54" type="1D" level="1" scaling="uint16"/>
<table name="WGDC Correction interval #2" category="Turbo" address="1a56" type="1D" level="1" scaling="uint16"/>
<table name="MUT8A" category="MUT" address="3642a" type="1D" level="1" scaling="Hex16"/>
<table name="MUT8B" category="MUT" address="3642E" type="1D" level="1" scaling="Hex16"/>
Instructions for ECUFlash
Variable for boost control: Stock will read 898A. Change it to 8984. The table is in hex format, so you will have to enter it as 0x8984
The "Load Error RAM Address" and "Load Error RAM Address in Load Error Table" will both read: 8866. Change both to 802A (again, you'll need to enter it as 0x....)
WGDC Correction update delay: Use table #1. Table #2 is for when the vehicle speed exceeds the boost limiting speed. Set the value anywhere from 1 to 10. Each unit is approx 0.08 to 0.1 sec.
Change MUT8A will read 8913. Change it to 802B (again enter it as 0x....)
Change MUT8B will read 8D9F. Change it to 8D21 (again enter it as 0x....)
Save the ROM file and upload it to your ECU. Then go to the instructions below for setting up EvoScan.
Old Apr 7, 2008 | 02:44 PM
  #205
mrfred's Avatar
Nice! One quick question, and then I'll move it up into my instruction area. Did you verify that 0xFFFF802A is an unused RAM address?
Old Apr 7, 2008 | 07:11 PM
  #206
laramie_05MR's Avatar
Thanks for the info
Old Apr 8, 2008 | 12:29 AM
  #207
evo828's Avatar
Yes - I checked on the dissassembly
Old Apr 8, 2008 | 06:36 AM
  #208
mrfred's Avatar
Thanks. Copied your instructions into the first post.
Old May 22, 2008 | 10:00 AM
  #209
Gpunkt's Avatar
can anyone help me with Boostcontrol mod and ROM ID 88840017 ?
i have attached a Logfile.
thx
Gerhard
File Type: zip
Old Oct 6, 2008 | 05:10 AM
  #210
evo828's Avatar
Somehow I see a discrepancy between the logged "desired load" and the BDEL+LoadOffset as in tables. I am on 96530006. The chart shows it - although the difference is small - it is not linear - so I do not how to explain it. Any idea?
In the chart - BoostLDOff is the logged MUT 8C (reading 8D25 address)
TableOffset - the dots represent the BDEL+Offset (manually from tables attached)
Attached Thumbnails ECU boost control mods-tables.gif   ECU boost control mods-chart.gif
