ECU boost control mods
Old Sep 7, 2007 | 09:35 AM
  #136
TouringBubble's Avatar
Originally Posted by ShamelessCookie
Everyone should try to tune with their TBEC table zero'd out. When you're as close as you can be, then re-introduce the TBEC.
this depends on your methodology ... I had a specific WGDC dialed in and ran with the TBEC table at 0. This worked fine. But, when the weather changes, the required WGDC for a give load/boost will change as well.
So, for instance, I tuned in the warmer months ... therefore, when it cools down I would have constantly been in - correction.
My approach was to take this unavoidable shift in to account and tune my WGDC lower than I currently need for my desired load/boost. This way, in the summer I'm in + correction, fall/spring is right about where I've got the WGDC set, and winter will be slightly -.
Also consider the "0" value most of us run in the -20 area of the TBEC map ... if you tune in the winter, your BWGDC may never get within -20 load in warmer weather and the correction will never kick in.
Old Sep 7, 2007 | 09:36 AM
  #137
Roger, do you have all 3 BDEL tables set to the same values? Your log doesn't seem to match your tables ...
Old Sep 7, 2007 | 09:48 AM
  #138
roger smith's Avatar
#1 is the one in the screenshot. I set #2 to a flat 230 and #3 and #4 to flat 220s so that I could figure out which table is being used, so I assume #1 since my logs all hover around 240.
And ShamelessCookie, yes people should tune boost the way you said. I did it and that's how I got my WGDC numbers but I guess my load is higher at peak so maybe I should try raising my BDEL at 3500. Or I'll get a proper log with error correction off (I wasn't logging 2byteLoad before)
Old Sep 7, 2007 | 11:20 AM
  #139
Have you taken the steps Mrfred suggested for getting the BDEL to reference the actual 2-byte load values or are you just trying to tune the TBEC table without the other changes suggested here?
Old Sep 7, 2007 | 12:24 PM
  #140
I did everything listed in this thread.
I'm going to try setting my correction timing to 4 and raise my desired load at peak today and see what happens... and maybe lower my WGDC at 3000
Old Sep 8, 2007 | 03:04 PM
  #141
mrfred's Avatar
Added instructions in first post for the EDM Evo IX 88840016.
Old Sep 10, 2007 | 10:09 AM
  #142
fil78's Avatar
Thumbs up
Mrfred
you are THE man !
if you ever plan to visit Paris - just pm me!
Old Sep 10, 2007 | 11:26 AM
  #143
vinogrados's Avatar
Originally Posted by fil78
Mrfred
you are THE man !
And Moscow also)
Old Sep 10, 2007 | 01:21 PM
  #144
MR Turco's Avatar
Does anyone know what to add to Mitsulogger XML to log these mods?
Old Sep 10, 2007 | 01:29 PM
  #145
Check out post #128 page 9;.
Maybe MrFred can add this to the first post?
Old Sep 10, 2007 | 01:32 PM
  #146
dudical26's Avatar
mrfred - are you still working on boost control without using load but rather just reading boost from the JDM map sensor?
Old Sep 10, 2007 | 01:38 PM
  #147
Pd1's Avatar
Pd1
https://www.evolutionm.net/forums/sh...d.php?t=293981
Old Sep 11, 2007 | 07:14 AM
  #148
dudical26's Avatar
thanks for the link, I did not see that before.
Old Sep 23, 2007 | 07:13 AM
  #149
silevo 8's Avatar
Thanks for the great work mrfred! Would you have time to check out 96420008?
Also, how is the base WGDC calculated? I know there are max WGDC tables available, but is there a base table that is the starting point that is then modified by the TBEC?
I'm a noob to the EVO cal, so any insight would be helpful.
Thanks
Old Sep 23, 2007 | 08:13 AM
  #150
burgers22's Avatar
The Max WGDC are the same as the base WGDC, mrfred discovered that the "Max" bit was misleading and the term "base" was a much more accurate term.
MB
