ECU boost control mods
Without any changes to the TBEC, target load, or BWGDC tables, the most probable effect is that boost will run lower. Might run the same. Will not run higher.
Thanks TouringBubble and mrfred. I will try it as is anyway. Can always set them back to stock if I don't like what it does. Weekend is looking busy so may have to try this tommorow
mrfred, can you comment on my two things in my post at the top of the page.
accident, look at my settings at the top of the page. also, yes only change delay #.
Anybody that wants a good starting point for a TBEC table, look at my settings above. With those settings, adjustments were perfect, weather they were big or small adjustments.
I just got mine set where it's usable. I used lower TBEC values (+/-3 maximum) and actually used a 4 for the delay timer. Anything below 4 was causing over correction. My boost is fairly solid in 3rd and 4th ... I didn't try second. The spike is significant in 3rd, but I get no knock so it's not an issue.
-On a drag style run though gear 1-4, I still get a dip after gettin back on the gas in the next gear. After that gets fixed, boost control will be complete and precise.
-Since your going though the code, have you found out the differences between the #1, #2, and #3?
Table #3 is only for when the vehicle speed exceeds the boost limiting vehicle speed. Table #2 never gets called into action by the ROM (even though the table exists). So, I'm pretty sure that Table #1 is all that matters.
For the dip, can you post a log showing what the load error is doing?
I was going to bring that up as well ... I was not able to log load error last night. EvoScan .99 doesn't like the line of code Mrfred gives in the first post. Un-checking the load error box let EvoScan run fine, so the problem is definitely in that line.
Mrfred, could you double check the Evoscan data item code?
Thanks for the updated code!
For informative purposes, here are my settings ...
(4th Gear)
As you can see, I've purposely set the BWGDC values lower than my desired load to compensate for temperature changes. When the weather cools off (it's been over 100* for some time now) the error correction table should have to work less to meet the desired load. This should aid in reducing overboost in cooler weather.
(4th Gear)
At high rpm, it appears that the boost control system is maxed out and cannot reach your desired load. It might be better to pull the BDEL down there to match the max load that you can acheive. This will again prevent the WGDC from getting unnecessarily pumped up.
One thing that may work for better automated fine tuning of the WGDC might be to using a "rising rate" on the TBEC table. Something like:
-20 0
-10 10
-8 6
-6 3
-4 2
-3 1
-2 0.5
-1 0
0 0
1 0
2 -0.5
3 -1
4 -2
6 -3
8 -6
10 -10
20 -20
This way, the corections are very small when the error is small, but then become rapidly much larger as the error becomes larger.
