Weird Thing With My Ecu Map!!
Old Aug 15, 2007 | 05:50 AM
mscorei's Avatar
Hello, I'm newbie in using EcuFlash, but I watched the tuturiol and so I downloaded my car's map. What surprised me was that when I looked at the Stationary Rev Limit it had the value of 2125!!!! Normally is 5000 as I know. Why is this?? I never uploaded any map or do something with my ecu. I changed it to 5000 as it normally should be and uploaded, and the car works fine. Please help. Also have EvoScan if you think is needed.
P.S. used the tactrix cable
Old Aug 15, 2007 | 06:29 AM
TouringBubble's Avatar
It's using an incorrect definition file it seems. I'm not sure which definition you should be using, but maybe someone will chime in.
Either way, you should probably change that value back to 2125 because it's not the stationary limiter that you've changed.
Old Aug 15, 2007 | 03:19 PM
mscorei's Avatar
are you sure? because in the stationary limiter field I changed the value. what is wrong?
Old Aug 15, 2007 | 03:24 PM
mplspilot's Avatar
You changed something else. If it says 2125 it's probably something else you're changing, which you should not. You need to read more about definition files.
Old Aug 15, 2007 | 03:45 PM
mscorei's Avatar
ok so how do I load the correct definition file?
Old Aug 16, 2007 | 02:15 PM
burgers22's Avatar
Hi
Post up your ECUs Internal id. Find this in the ROM Info part of the left hand plane.
MB
Old Aug 16, 2007 | 03:30 PM
mscorei's Avatar
it's 88840016
Old Aug 19, 2007 | 02:07 AM
mscorei's Avatar
also I have installed ecuflash to another laptop with win xp, i used ecuflash 1.29, i downloaded my map and its 2125 too that value.. But when i try to launch my rev stay al 5000. If I change that value to 5500, when I launch it stays to 5000 again..
Old Aug 19, 2007 | 07:45 AM
wreckleford's Avatar
What they said.
Old Aug 19, 2007 | 02:40 PM
mscorei's Avatar
not helping me at all.. how the hack to choose those definition files.. i have an evo IX
Old Aug 19, 2007 | 02:49 PM
03SilvaEvo's Avatar
I think I'm having the same problem as you. When I downloaded my car(03) map, I looked at the stationary rev limiter and it was at "0" and I know thats not where its set at.
Old Aug 20, 2007 | 01:55 AM
mscorei's Avatar
someone please help us, I cannot tune my ecu if I do not have the correct map.
Old Aug 20, 2007 | 05:44 AM
Mellon Racing's Avatar
send your rom to me and I'll take a look at it for you to see if I can help. send me a pm with a link to this thread if you're interested so I'll remember what it's about and I'll send you my e-mail address
The DarKnight
15
Feb 8, 2014 01:59 PM
evo9_jdm
May 13, 2011 07:22 AM
sleeper04
Oct 16, 2010 12:59 AM
mitsuatb
Sep 2, 2007 03:04 PM
Evo_Pma
Jul 6, 2007 09:32 AM
