how-to: ECU-based direct boost control
Old Dec 28, 2007 | 08:48 AM
  #166
GTLocke13's Avatar
Everything is stock in that log, except for the MIVEC table. Stock boost control, timing, fuel, etc...
Old Dec 28, 2007 | 09:23 AM
  #167
mrfred's Avatar
Originally Posted by juyanith
... As long as I'm correcting you I'll add that where you mention adding to the evo9base.xml for the 94170008 ROM when I'm pretty sure you mean the evo7base.xml file.
Fixed that just now. Thanks again. :-)
Old Dec 28, 2007 | 02:58 PM
  #168
RazorLab's Avatar
Try bumping the BCLO to 100 and you should see smoother boost.
Old Jan 13, 2008 | 09:36 AM
  #169
EE's Avatar
EE
hi mrfred, thx for this thread really amazing.
I'm ok with load based boost control, but would like to increase the
frequency the ecu checks & correct wgdc vs load (in my case it's load...).
what should i do with my xml file in order to achieve this modification??
i have a edm evo 9...
Regds
Old Jan 13, 2008 | 10:43 AM
  #170
mrfred's Avatar
Hi. This is the thread for you:
https://www.evolutionm.net/forums/sh...d.php?t=288408
Hopefully, you have the 88840016 ROM.
Old Jan 13, 2008 | 03:49 PM
  #171
EE's Avatar
EE
yup that's the rom i have, thx mate
Old Jan 19, 2008 | 08:15 AM
  #172
FuelsResearch's Avatar
Dumb question: To rescale rpm axis is MWGDC (BWGDC) tables, if one changes rpm values by clicking cell and entering desired rpm does that make an effective change to the table in the rom?
Old Jan 19, 2008 | 08:32 AM
  #173
mrfred's Avatar
Yep. All three BWGDC tables will change when one is changed. I think that the target boost table will change as well.
Old Jan 19, 2008 | 10:25 AM
  #174
I assume this applies to rpm axis in other tables as well (open loop load, fuel map, ign., etc.)?
Old Jan 19, 2008 | 04:58 PM
  #175
burgers22's Avatar
No Open loop, fuel and ignition all use different RPM addresses to BDEL and each other.
MB
Old Jan 19, 2008 | 05:22 PM
  #176
mrfred's Avatar
If there are sets of tables, e.g., spark tables, fuel tables, changing the axis on one table will cause it to change on the others too. Changing the rpm axis on the spark table will not change the rpm axis on the BWGDC table though.
Old Jan 21, 2008 | 07:49 AM
  #177
Looks like I've hijacked this thread. So since this method doesn't work well with the stock bcs/ pill system, will using the GM 3 port allow boost control to work in the way the method intends. I really like this method as it is independent of weather change, where I live we can see great variance in day to day weather (i.e. last week it was 60 F at one point, then it snowed, now its in th 20s).
Old Jan 21, 2008 | 08:14 AM
  #178
nj1266's Avatar
Yes, the GM 3-port works with direct boost control. The only downside is you will have to splice into the harness to connect the 3-port.
Old Jan 21, 2008 | 09:11 AM
  #179
Thanks, don't mind the splicing at all. I just don't want to get it 90% dialed in and learn that there is a major shortcoming ( as I have recently with the stock bcs).
Old Jan 21, 2008 | 09:32 AM
  #180
nj1266's Avatar
I know what you mean...I spent hours dialing in the direct boost in 3rd gear. It was perfect. Then I tried it in 4th gear and the car was overboosting and the BEC (set as mrfred told me) was pulling boost like crazy.
I was really disappointed. I just acquired a Vishnu bleeder. It is the same one that mrfred is using. I might try direct boost control with it. mrfred uses it with direct boost and it works.
